Hello,
I'm new at the forum. I may need schooling. I have a 08 z4 3.0l that's burning oil at 130k miles. Is there a video on this job anywhere. Or maybe an alldata.
Valve stem seal replacement instructions.
- Rockhopper
How much is it using? Puff of smoke on start up is valve stem oil seals.
No not a puff of smoke on start up at all. Only at high rpm's. Hard to tell how much oil. The sensor continually says oil level is ok. I've checked pcv valve. Only thing left is valves or rings right?
- Rockhopper
Thats not typically a symptom of valve stem seals. I think you need to investigate more - do a compression test followed by a leakdown test.
Any smoke on over run or if you leave it to idle then blip the throttle?
2009 09 Carbon Black Cinnamon E86
