So I left the E86 into my local BMW dealership tp have them do an Inspection 1 and MOT prep on it.
Here are their findings:
'Possible' MOT failure on passenger side headlight unit due to condensation and inner covers peeling.
Both front calipers beginning to stick and slight overheating on pads/discs
Rear passenger caliber beginning to stick and over heating etc
Both rear brake lines from ABS sensor to under cover at rear axle have signs of rusting, pitting and corrosion. Possible failure.
Oil leak from rocker cover, needs new seal. Shouldn't fail MOT, but probably will be mentioned
They said that the above may be possible failures, but will depend on the person performing the test.
In NI our MOT's are done in government run facilities and not your little local mechanic. So sometime they can be very jobs-worth and toe the line testers etc
They don't think the calipers issue will be failure. The pads and discs as they are, are good, and the car is braking within its required limits. Not even sure if it will be an advisory.
I asked if the headlight will be an issue as it hadn't had condensation for a while. They said it would only fail if there was moisture inside it affecting the light pattern.
So it will go to the MOT at the start of May and I will see what comes of it.
I did ask them to crack all the brake caliper carrier bolts and re-torque them for me. They refused point blankly!
I asked if I brought my own pads and discs, would they install them. They refused point blankly!
I asked if I agreed to them changing the pads and discs and they sheared a bolt on the carrier, who is accountable. They said they would be.
Given that (fingers crossed) the brakes aren't an MOT issue, I think I will still try to get them off myself with constant penetration fluid before resorting to other help.
Need to start reading up about replacing this seal on the 3.0 N52 engine.
Anyone point me in the direction of good videos/guides for this specific one?
My Z4...the car that keeps on giving........
