2003 E85Car wont start
- Roberltd2
.......and welcome to the Forum!
2007 E85 2.5 si Sport in Montego Blue.
1994 Eunos J2Ltd - sold and now undergoing restoration.
1963 Triumph Thunderbird.
- colb
You have not made it clear if the engine turns over when the ignition key is turned to start position.
If it turns the engine then could be the cars EWS system is not being released to allow ignition to take place, this could be due to the transponder chip in the key not being read by the aerial around the ignition barrel or the transponder being absent from the key fob, not unknown for them to be lost if the key breaks open. Not unknown for the sync between the EWS module and the Main ECU module to loose sync and prevent starting. The two can be re-synced using INPA software.
Z Shed Cymru member
1999 1.8 Z3
2003 2.5 Z4
1998 Honda Deauville 650
1999 1.8 Z3
2003 2.5 Z4
- Trav
Have you checked and cleaned the ground connection? Not just replace the starter. Clean both ends. Also your multimeter is probably only rated to 10A DC with thin leads. I wouldnt recommend putting this inline with a starter with a fuse rating of 40A. Did you mean to say you measured the voltage?
Z4MR A.W.
- enuff_zed
Whereabouts are you?
Plenty of experienced people around that may be close enough to help out.
For example, I know a man who can tell the EWS and DME to ignore each other so you would eliminate the chance it's an immobiliser issue.
It looks like it is the immobilization circuit tested with a meter. I get the right signals to the module under the dash and nothing out. If I disconnect the starter and directly apply power to the starter with it still installed I can get it to engage properly.
- bigwinn
Where are you based?Zim11911 wrote: ↑Sun Apr 02, 2023 2:44 pm It looks like it is the immobilization circuit tested with a meter. I get the right signals to the module under the dash and nothing out. If I disconnect the starter and directly apply power to the starter with it still installed I can get it to engage properly.
EWS Delete PM me
Coding- airbags etc PM me
EWS Delete PM me
Thank you for the welcome to the forms. When I put the key in the ignition all of the internal electronics turn on, and I hear a faint click come from the ECU box by the firewall and driver-side strut tower. I have used an industrial-rated fluke meter rated to 500 amps and placed it in line with the firewall-mounted battery positive cable to a grounding point on the Strut tower. With that test, I do not see any current draw or amperage when the key is engaged I do see 12.8 volts and it drops to 12.51 when the key is engaged. I went to the ignition switch and used the pin out I was able to find and was able to see voltage pass through on key rotation for the ignition switch. I tracked those lines back down and ran into nothing coming out of the immobilization unit underneath the dash. I do not know if this is related to the key or the unit itself. The key will unlock the car from about 5 to 8 feet away. When I disconnected all of the cables from the starter and took the battery and directly wired it up with an interrupt switch. I was able to get the starter to engage, and the flywheel rotated properly. I visually inspected and checked resistances for most of the grounds. All the ones I was able to easily find an access. I am in Houston Texas
- paddy wright
I bought a C310+ which seems great
- Rockhopper
You won't see any current draw if you do it like that, you need to take the lead off the back of the starter and put the meter in series with it (or find the other end of the lead and disconnect it). A clamp meter would be a whole lot easier.
- enuff_zed
Ah damn!
Most of the people on here are UK based.
It may be that you have to get yourself set up with the software then pick someone's brains over here to help you sort it.
Solved kinda!!
I bypassed the EWS, and the car will start and run with it bypassed. The EWS sees the key but seems to not communicate correctly with the DME after I resynchronized them the problem seems to have gone away any idea why they would fall out of sync? Any way to prevent this replace both replace one?
- enuff_zed
Calling bigwinn!
Maybe you could explain to Zim11911 how you found and used that software to tell the DME not to bother talking to the EWS?
That could be an easier or cheaper fix?
- bigwinn
Sure
I’ll link in the post where I was advised to use specific software
Hold on
Hold on
EWS Delete PM me
EWS Delete PM me
- bigwinn
Can’t find the post
However I downloaded MS45 quick flash from bimmertools
Don’t expect any product support mind you
It worked when we figured out what we were doing on martins car and several afterwards
EWS Delete PM me
EWS Delete PM me
- bigwinn
EWS Delete PM me
EWS Delete PM me
