Had a full service and have been advised my parking brake is on the borderline of failing an mot. It should be holding a lot firmer. Have been advised to have the parking shoes replaced, but I thought these could instead be adjusted?
Is this wishful thinking on a car with 125,000 mikes or is it plausible I don't have to fork out? Seen as its an automatic it's not a huge deal to me.
Parking brake worn?
- skmattwell
- enuff_zed
Parking brake worn?
Well you'd need to start by getting the discs off and checking the shoes inside for wear.
It could just be that they're glazed, in which case a rough up with emery cloth, and the same to the inside of the drum, coupled with a tweak of the adjusters could essentially be a free fix.
Parking brake worn?
A set of shoes is less than £30 and takes 45 mins to change.
Easy job done
Easy job done
2009 09 Carbon Black Cinnamon E86
- MikeyH
Parking brake worn?
That's a lot of Mikes for one carskmattwell wrote: ↑Tue Mar 28, 2023 7:46 pm Had a full service and have been advised my parking brake is on the borderline of failing an mot. It should be holding a lot firmer. Have been advised to have the parking shoes replaced, but I thought these could instead be adjusted?
- enuff_zed
Parking brake worn?
Yeah, but Mikes are known for being very shortMikeyH wrote: ↑Tue Mar 28, 2023 8:51 pmThat's a lot of Mikes for one carskmattwell wrote: ↑Tue Mar 28, 2023 7:46 pm Had a full service and have been advised my parking brake is on the borderline of failing an mot. It should be holding a lot firmer. Have been advised to have the parking shoes replaced, but I thought these could instead be adjusted?
- MikeyH
Parking brake worn?
Very trueenuff_zed wrote: ↑Tue Mar 28, 2023 9:56 pmYeah, but Mikes are known for being very shortMikeyH wrote: ↑Tue Mar 28, 2023 8:51 pmThat's a lot of Mikes for one carskmattwell wrote: ↑Tue Mar 28, 2023 7:46 pm Had a full service and have been advised my parking brake is on the borderline of failing an mot. It should be holding a lot firmer. Have been advised to have the parking shoes replaced, but I thought these could instead be adjusted?
