WANTED Cruise Control Loom
- Calps
Cruise Control Loom
I have the stalk, just need the loom.
If anyone has one they're willing to part with (ideally with installation instructions), or can point me in the correct direction, that'd be great.
MelZ: Black Sapphire Z4C
Cruise Control Loom
Hey Calps, srhutch is your man, he's the cable guy you need, just send him a pm
- JINGLE
Cruise Control Loom
I think a forum member used to make custom cruise looms for the different engines, I had 1 off them and it worked for my 2.0i but now since the engine has been upgraded to the 3.0Si I need another so I’ll see if I can find them (think it may have been srhutch)
- Number5
Cruise Control Loom
I've just made SRHutch aware of your request. He'll be along shortly
Alpina Roadster #307
Porsche Boxster GTS
Previous Zs
Stratus E86
G29 30i
1x Imola Z4MR
Alpina #019
10x E85 Se/Si Roadsters
2x E89's
Porsche Boxster GTS
Previous Zs
Stratus E86
G29 30i
1x Imola Z4MR
Alpina #019
2x E89's
- Calps
Cruise Control Loom
Thank you all.
I was aware srhutch had provided these in the past, however I didn't know if that was still the case, and also wasn't sure of engagement etiquette, and so opted to post here instead.
Sounds like the forum equivalent of the Bat Signal has been activated though
- srhutch
- Moderator
Cruise Control Loom
Jingle, you just need to plug your loom in a different position on the ECU. I can resend the instructions, pm me your email.JINGLE wrote: ↑Tue Mar 28, 2023 12:24 pm I think a forum member used to make custom cruise looms for the different engines, I had 1 off them and it worked for my 2.0i but now since the engine has been upgraded to the 3.0Si I need another so I’ll see if I can find them (think it may have been srhutch)
- srhutch
- Moderator
Cruise Control Loom
Hi calps, I'll on the settings over later.Calps wrote: ↑Tue Mar 28, 2023 3:40 pm Thank you all.
- Calps
- JINGLE
Cruise Control Loom
Hi mate, I still have your original email with the instructions... problem is the cars main loom has been removed for the 2,0i and replaced for the 3.0Si loom so I don't actually have any idea what wires are still there, or scrapped with the old loom etc. might just be easier to buy another 3.0Si loom if you still have 1?srhutch wrote: ↑Tue Mar 28, 2023 8:15 pmJingle, you just need to plug your loom in a different position on the ECU. I can resend the instructions, pm me your email.JINGLE wrote: ↑Tue Mar 28, 2023 12:24 pm I think a forum member used to make custom cruise looms for the different engines, I had 1 off them and it worked for my 2.0i but now since the engine has been upgraded to the 3.0Si I need another so I’ll see if I can find them (think it may have been srhutch)
- enuff_zed
Cruise Control Loom
I cannot think of anyone less likely to need cruise!JINGLE wrote: ↑Wed Mar 29, 2023 8:38 pmHi mate, I still have your original email with the instructions... problem is the cars main loom has been removed for the 2,0i and replaced for the 3.0Si loom so I don't actually have any idea what wires are still there, or scrapped with the old loom etc. might just be easier to buy another 3.0Si loom if you still have 1?srhutch wrote: ↑Tue Mar 28, 2023 8:15 pmJingle, you just need to plug your loom in a different position on the ECU. I can resend the instructions, pm me your email.JINGLE wrote: ↑Tue Mar 28, 2023 12:24 pm I think a forum member used to make custom cruise looms for the different engines, I had 1 off them and it worked for my 2.0i but now since the engine has been upgraded to the 3.0Si I need another so I’ll see if I can find them (think it may have been srhutch)
- Usel
Cruise Control Loom
For the road works on a11?
- JINGLE
Cruise Control Loom
Haha only just seen this reply, and it’s exactly for that…. Cruising along at 40 is a chore
