HI Peeps!
So I've been away for a couple of weeks and my E86 has been parked up outside on the drive (handbrake off).
Went out today for a drive and noticed that there is a wobble from the steering wheel when building up speed, so pulled over and noticed there was that smell that something is heating up, and the drivers side wheel was warm to touch.
Am I correct in thinking that leaving the car parked for a long period, and due to all the recent rain has caused the caliper to stick.
I always thought leaving the handbrake off would avoid such issues.
Well if it is the caliper can it just be cleaned up or is a new one the only option
What's a good OEM quality brand and where's the best place to source one, ie: GSF, ECP?
Possible Sticky Brake Caliper?
- Rockhopper
The handbrake doesn’t use the calliper, it’s got its own shoes. Seized rear callipers are quite common and not hugely expensive to replace.
Hot wheel means sticky caliper. Handbrake operates on rear wheels only, and doesn't use the caliper.
Rebuilding calipers is straightforward but equally they're cheap to buy new/remanufactured. I wouldn't worry about brand - a Z4 sliding caliper is a simple item.
Thanks guys,
Just found a PAGID item for £107.54 at Carparts4less.
https://www.carparts4less.co.uk/brake-caliper
Also you think its Ok to drive 20 mins to my mechanic the way it is at the mo' without causing any further damage.
Unlikely needs a caliper, I'd remove the slider pins, clean and regrease and same with the pads. More often than not it will be them causing the binding and not a caliper piston
£35 here. Won't be a problem driving a short distance. https://www.spareshut.com/products/bmw- ... tsQAvD_BwEQUIKSTER wrote: ↑Sun Mar 19, 2023 7:17 pm Thanks guys,
Totally agree if OP was DIYing, especially as this would not require bleeding. But as he's taking it to a mechanic, might as well fit a new one straight away.Unlikely needs a caliper, I'd remove the slider pins, clean and regrease and same with the pads. More often than not it will be them causing the binding and not a caliper piston
That’s offensive. Pagid calipers for E86 are available from Halfords (who are supplied by ECP, whose “discount” brand is Carpart4less) for £51.36, rears are £35.04. Others maybe cheaper, e.g. AUTODOC, but you may have to wait.QUIKSTER wrote: ↑Sun Mar 19, 2023 7:17 pm Thanks guys,
2003 Maldives Blue 3.0i auto
