Misfire
enuff_zed
Misfire
Post by enuff_zed » Sat Mar 18, 2023 10:39 pm
Z4_LZF wrote: Sat Mar 18, 2023 10:10 pm A quick update.
Yanked out the plug in from the OBD port. Cleared the codes using my mates Code reader.
Said that there was a crankshaft position fault.
Car started up perfectly. Went for a 6 miles run, the car drove fine. In fact, seemed far smoother than previously.
Went for another run, car again, drove perfectly.
It might be that the plug in, which was said to be some sort of performance and fuel mod, was at fault!!
Well that could be a cheap fix then.
Just don’t try to sell the thing on here :poke: :rofl: :rofl:
HQ of 'Norfolk Zed Rescue'.
Z4_LZF
Misfire
Post by Z4_LZF » Sat Mar 18, 2023 10:50 pm
enuff_zed wrote: Sat Mar 18, 2023 10:39 pm
Hope so, it’s due to go in to the garage I bought it from this week so that they could have a look, but I’m too impatient!!
E30 320 touring
E36 318i saloon
E36 318is coupe
X3 20d msport
E39 525ise
E46 320i msport touring
E60 520d se saloon
E70 X5 30d msport
F40 118i msport
E85 2.5 roadster
Z4_LZF
Misfire
Post by Z4_LZF » Sun Apr 16, 2023 4:59 pm
Afternoon all.
Back to my misfire, which, remarkably, after 150 miles or so, has reappeared.
Misfire, followed by poor running, kangarooing, then EML.
I’ll need to get the codes read, but I’m Guessing it’s the crankshaft position sensor failing. As they were the codes thrown up last time around.
E30 320 touring
E36 318i saloon
E36 318is coupe
X3 20d msport
E39 525ise
E60 520d se saloon
E70 X5 30d msport
F40 118i msport
E85 2.5 roadster
Z4_LZF
Misfire
Post by Z4_LZF » Tue Apr 25, 2023 11:32 pm
It’s turning in to a puzzler. Had a local garage take a look, nothing obvious.
Fault codes threw a variety of timing related codes up.
When it begins to misfire, begin lurching etc, if I pull over and turn the engine off, it restarts and drives fine for a while.
Thinking it might be a sticking vanos solenoid.
Has anyone had anything similar? Have booked in to a BMW specialist for them to take a look.
E30 320 touring
E36 318i saloon
E36 318is coupe
X3 20d msport
E39 525ise
E60 520d se saloon
E70 X5 30d msport
F40 118i msport
E85 2.5 roadster
Special Kay
Misfire
Post by Special Kay » Tue Apr 25, 2023 11:51 pm
I think its just good practice to take out your vanos solenoids to clean with some brake cleaner. One less item you could eliminate if they're not faulty :thumbsup:
Z4_LZF
Misfire
Post by Z4_LZF » Mon May 15, 2023 11:35 pm
:thumbsup: cheers. Car is booked in for an oil service tomorrow at my local Indy. What a nightmare trying to get an appointment at a garage!!
Hopefully they can pinpoint the problem.
If I let the car warm up for a couple of minutes, I don’t have a problem. Depending on their findings, vanos solenoids and check valves/filter are on the to do list.
Incidentally, there does t seem much room to get at the vanos solenoid valves??
E30 320 touring
E36 318i saloon
E36 318is coupe
X3 20d msport
E39 525ise
E60 520d se saloon
E70 X5 30d msport
F40 118i msport
E85 2.5 roadster
smorris_12
Misfire
Post by smorris_12 » Tue May 16, 2023 10:39 am
Z4_LZF wrote: Mon May 15, 2023 11:35 pm Incidentally, there does t seem much room to get at the vanos solenoid valves??
Entirely done by feel! One thing about wielding spanners is you develop eyes in your fingertips.
Scott
Where are we going and why am I in this handbasket?
2006 Z4 2.5si Silbergrau und rot
Z4_LZF
Misfire
Post by Z4_LZF » Tue May 16, 2023 10:42 pm
Took the Zed to my local Indy garage today for an oil service and a diagnosis of the misfire. One of the coil packs was fitted incorrectly and not properly seated. The codes indicated a problem with the vanos inlet solenoid so this was removed, cleaned and tested. It was apparently fine. Apparently they can be problematic if oil pressure is low or the incorrect grade of oil is mixed/used.
Seemed fine earlier, hopefully it’ll be okay in the morning.
E30 320 touring
E36 318i saloon
E36 318is coupe
X3 20d msport
E39 525ise
E60 520d se saloon
E70 X5 30d msport
F40 118i msport
E85 2.5 roadster
enuff_zed
Misfire
Post by enuff_zed » Wed May 17, 2023 8:51 am
Z4_LZF wrote: Tue May 16, 2023 10:42 pm Took the Zed to my local Indy garage today for an oil service and a diagnosis of the misfire. One of the coil packs was fitted incorrectly and not properly seated. The codes indicated a problem with the vanos inlet solenoid so this was removed, cleaned and tested. It was apparently fine. Apparently they can be problematic if oil pressure is low or the incorrect grade of oil is mixed/used.
And there is a lesson for us all.......
While everyone says 'get the codes first' we need to not overlook all the basic checks we would have done automatically on cars a few years ago.
Hope that cures it for you.
Z4_LZF
Misfire
Post by Z4_LZF » Sat Jun 10, 2023 8:53 pm
enuff_zed wrote: Wed May 17, 2023 8:51 am
Seems fine now. Touch wood.
E30 320 touring
E36 318i saloon
E36 318is coupe
X3 20d msport
E39 525ise
E60 520d se saloon
E70 X5 30d msport
F40 118i msport
E85 2.5 roadster
