WANTED E85/6 bottom cover in front of wheelarch
Hi,
I recently ordered this item from the dealer webshop, finding out they can no longer supply it (from Germany). All other sources are out of supply as well
The one on my car is split and I need a new one since it is beyond repair.
Part number: 51717168996 (bottom right)
#6 on realoem: https://www.realoem.com/bmw/enUS/showpa ... Id=51_4951
Does someone have a good one lying around they want to sell?
'06 BMW Z4 Coupe 3.0SI - Titansilber
'11 Mini Cooper S - British Racing Green
'11 BMW 523i Touring - Sophistograu
Online
These often split, but can usually be successfully repaired using a plastic stapling/welding kit. Much cheaper than buying a new one, although no good if you’re OCD about having perfect parts.
2003 Maldives Blue 3.0i auto
- jock156
These parts are becoming like hens teeth
- jock156
Thanks for thinking along, I am from the Netherlands.
Jay Winship or Maz Cool or EZ & BW don’t say anything to me, are they parts suppliers?
Currently trying to source a bmw breaker that has a Z4 without a smashed front to find a piece still intact. Unfortunately mine was held on by the screws to the surrounding elements only, real bad. Yes is not a visible parts, though should give a certain structure. Imagine what happens down there below the bumper when doing 240 on the Autobahn
Don’t mind to buy one new if still available but probably better off with one from a salvage car, only where to find one?
- jock156
EZ = Enuffzed on this Forum
BW= Bigwinn on this Forum
The other 2 guys search for them on FB and message them! They are Z4 breakers
- enuff_zed
E86|3.0SI, I'm sorry but I recently sold the pair I had.
Try bigwinn, umfaan, or Street on this forum.
I've referenced them so they should get a notification anyway.
As you're aware, these panels are fragile and you may have to settle for one with a little bit of wear.
Good luck
Good luck
- bigwinn
I’m out sadly
EWS Delete PM me
Coding- airbags etc PM me
EWS Delete PM me
- Street
Yeap I’ve got a pair
3.0si Coupe Sapphire Black Target 300k miles
3.0si Coupe Sapphire Black Why have 1 when you could have 2!!
Serial Zed tinkerer. Always looking for the next Zed project
@street
That sounds great, do you want to sell the righthand side one?
