The brake pedal in car has a lot, well I think it's a lot, of side to side 'play'.
Any other auto drivers experienced this?
I'm guessing it's bushes or similar. I'll get on Real OEM see if I can see what's what.
2010 Auto brake pedal
Current:
2014 F15 X5 30d Msport in Sapphire Black
2010 E89 SE sdrive 30i auto in Sapphire Black
Previous:
2016 4 series 430d Gran Coupe in Carbon Black
2009 E89 SE sdrive 30i in Alpine White
Previous:
So after some digging around, it appears to be a fairly common issue.
It seems BMW fit rubber bushes that are inadequate for the job. There are plastic bushes available which help, apparently.
Current:
Previous:
Previous:
- Marcoose
I have a DCT with the 'auto' brake pedal. (Which I don't use since I've installed the aux LFB pedal.) That said, the OEM brake pedal has no play whatsoever.
2016 35is, monoballs, camber plates, KWV3, PS4S, xHP, MHD, LFB pedal, flat bottom wheel, red indicators, black headlamps
Last mot I had an advisory on the same thing 2010 3.0si, personally did not think it was too much movement
Changed to the new plastic bush, fiddly job
White one was the new one
- Bush
- 7A3AEFD8-D0E5-4BDC-821C-C01E957748EB.jpeg (157.85 KiB) Viewed 243 times
I had an attempt at replacing the bushes in mine yesterday. Quickly established either the car is too small, or I'm too big
Did you move anything out the way to get at the clip that retains the pedal?
Current:
Previous:
Previous:
I took the trim out but it is really awkward job and not a 2 minute onet90ark wrote: ↑Sun Mar 26, 2023 7:09 pmI had an attempt at replacing the bushes in mine yesterday. Quickly established either the car is too small, or I'm too big
So, I replaced the bushes on the brake pedal with some oilite bushes instead of the OEM plastic. Well, when say 'I' ... had some help from my brother who is a somewhat smaller in stature than me
What. A. Job!!
No movement in the pedal now, though... and a job that won't have to be done again.
Now, if I can just find the leak into the boot....
What. A. Job!!
Current:
Previous:
Previous:
