Yes, also a good suggestion. Will let you know how I get on once I've tried it.
OBD Flap/Cover
OBD Flap/Cover
And a result for industrial strength velcro (which I had lying around )
Took about 5 minutes, closes perfectly and should have some resilience to vibration. I decided only to add it on one side as a hinge, but it could
be used on the other if I find it has a tendency to pop open. The trick is to fold the loop (soft, carpet-like) section over so there's no sticky residue and it doesn't attach to anything you don't want.
I'll keep you posted as to how it holds up on the road. The nice thing with this fix is that I've not made any permanent changes.
- IMG_6706.jpeg (171.31 KiB) Viewed 81 times
- IMG_6705.jpeg (175.34 KiB) Viewed 81 times
- IMG_6704.jpeg (189.7 KiB) Viewed 81 times
- IMG_6703.jpeg (142.78 KiB) Viewed 81 times
- IMG_6702.jpeg (111.9 KiB) Viewed 81 times
- IMG_6707.jpeg (144.5 KiB) Viewed 81 times
- B21
OBD Flap/Cover
I see you have a remote boot lid release button down there..wonder when it was deleted ?
OBD Flap/Cover
That's just to confuse people...
It's a Chinese replacement - the blank was missing from the car and the easy thing was to get a replacement
button to fit. There doesn't seem to be any wiring to plug it into unfortunately so it's just decorative.
- B21
OBD Flap/Cover
Ah well…at least I was paying attention to the pics
OBD Flap/Cover
If I could wire it up, I would, but I don't want to hack into the loom
