Drop links for KWV 3's...?
"M" Specific discussion
Online
Ed Doe
Post by Ed Doe » Sun Mar 19, 2023 2:01 pm
john-e89 wrote: Sun Mar 19, 2023 1:16 pm
Ed Doe wrote: Sun Mar 19, 2023 8:32 am
Slideways wrote: Sun Mar 19, 2023 2:33 am When installing adjustable suspension, one should plan on corner balancing and dialing out sway bar preload; otherwise, the suspension modifications will be suboptimal. If it were not for the shorter KW endlinks, one adjustable endlink would be enough to dial out preload.
Oh christ, and I can well imagine that would make a difference to the handling dynamic of a car never driven on track. Come on mate I totally understand why adjustable droplinks are useful, but if the op isn't corner weighting the car, or racking the car, it's not exactly any use is it?
I'd thought you might be able to feel the adjustments on the road, but I've never used adjustable ones tbh.
What are you expecting to feel?
If you corner weight the car, you'll find the suspension may be a slightly different height across the axle. By using adjustable droplinks (or by buying coilovers with adjustable droplink mounting points like intrax for instance), you will effectively then be able to dial out any consequential pre-load on the arb. Will the preload be minimal? Yes. Will you feel that on the road? Very unlikely (imo).
It's just my opinion, for sure do what you feel is right for you, but honestly I would say adjustable droplinks are a waste of time and money unless you're tracking the car and therefore fully corner weighting it after fitting the suspension. If you're just lowering the car a bit and wanting the ride height to be visually equal across the axle then I'd not worry at all.
Just touching on your point regarding droplink length, if you drop the ride height you're effectively lowering the chassis relative to the mounting point on the damper. So the angle between the droplink and the arb will change, and this will affect the effective 'spring rate' of the arb. By reducing the length of the droplink, you bring the arb angle relative to the droplink back to the oe angle, so the rate becomes the same as oe again. Ultimately this is stuff that matters if you're chasing tenths on track - I honestly wouldn't worry a jot for road use.
Carbon Black '07 M Coupe: Intrax 1k2 Coilovers, AP-Racing, Raybestos ST45s, Tillets, Schroth, Vibratechnic, Apex EC7, Strongstrut, Eventuri, H&S, RTD, 4.1FD :evil:
Silver Grey '06 3.0si Coupe - SOLD :(
john-e89
Post by john-e89 » Sun Mar 19, 2023 2:25 pm
Ed Doe wrote: Sun Mar 19, 2023 2:01 pm
No that all makes sense Ed, I'm not going to track it, I don't want it much lower than standard either, I'll stick with OE, thanks for the more detailed insight than I was aware of. :thumbsup:
MR2 MK 2
E89 35is
G29
BMWZ4MC
Post by BMWZ4MC » Sun Apr 02, 2023 3:39 am
I used adjustable drop links with mine only because the OEM drop links are not compatible with the combination of KW Clubsports / H&R ARBs.
S2000 GT - gone
Vanne
Post by Vanne » Thu Apr 06, 2023 2:54 pm
lol, def dont need corner balance for the road.. hell even on track sometimes.. prob spend the cash elsewhere...
Powered by Severn Tuning
plenty
Post by plenty » Thu Apr 06, 2023 3:29 pm
john-e89 wrote: Sun Mar 19, 2023 1:16 pm I'd thought you might be able to feel the adjustments on the road, but I've never used adjustable ones tbh.
If you're the sort of person who can tell the difference in the way a car handles when it's full of fuel versus half empty, or when you change tyre pressures by 2 psi, you might be able to notice. Most people can't.
mmm-five
Post by mmm-five » Thu Apr 06, 2023 3:38 pm
plenty wrote: Thu Apr 06, 2023 3:29 pm
Not sure about 2PSI or half-full of fuel...but 4-up in an Alfa diesel on Cross-Climates makes it understeer onto the grass at Schwedenkreuz, when 1-up doesn't :oops:
Trigger’s Z4MC
Some bits now over 163,000 miles, some less than 1,000 miles.
Individual Ruby Black, Individual extended champagne leather, plus many options
john-e89
Post by john-e89 » Thu Apr 06, 2023 7:03 pm
I'm not, never suggested otherwise, what I said was I 'Thought' as above, ...not 'I can'... :roll:
MR2 MK 2
E89 35is
G29
