4 warning lights popped up
As soon as I drove the car today, the lights came back on New sensor ordered
- pvr
At least it is the cheap one. The rear one which I have to change as well is more than twice the cost
Current:
911-50 Black - unique spec
X5M - 575 hp of fun in a V8
Abarth 595 Comp.
Z4 3.0si Black Sapphire
VW ID.3
Previous:
Z4 3.0 Toledo
Abarth 595 Comp.
VW ID.3
Previous:
Z4 3.0 Toledo
- enuff_zed
Which sensor was it?
Be sure to soak the mounting bolt in penetrating oil beforehand and use the exact size Allen key. 5mm or 6mm, can’t remember which.
Take it easy as you don’t want that bolt shearing off.
Last one I did we had to resort to Mole grips and removed the calliper to get enough purchase on the bolt.
- pvr
It is 5mm from my research
Current:
Abarth 595 Comp.
VW ID.3
Previous:
Z4 3.0 Toledo
Abarth 595 Comp.
VW ID.3
Previous:
Z4 3.0 Toledo
- enuff_zed
Cheers.
Old age setting in! Only did the job last weekend.
- pvr
I ordered the Torx replacement bolts on your recommendation, so when I do the jobs at least I have the replacements to go in.
Current:
Abarth 595 Comp.
VW ID.3
Previous:
Z4 3.0 Toledo
Abarth 595 Comp.
VW ID.3
Previous:
Z4 3.0 Toledo
Don’t you love it when it all goes right for once ! New sensor fitted without and problems, did a reset, and it nows drives without any warning lights
- pvr
Great stuff. I still haven’t done mine
Did you get it out ok without issues?
Current:
Abarth 595 Comp.
VW ID.3
Previous:
Z4 3.0 Toledo
Abarth 595 Comp.
VW ID.3
Previous:
Z4 3.0 Toledo
Came out a treat. Biggest struggle was getting the grommet back on the back of the strut !
- RickRob
Mine has just started displaying these 4 warning lights, but only intermittently. It doesn’t do it on a really smooth road.
Car has just come back from having a new starter motor fitted. Could something have been knocked to cause this?
///M Roadster. 2007 Black/Black. Rear spoiler, whippy aerial, mud flaps and gimp-style wind deflector!
- enuff_zed
Pretty sure it’s coincidence.
You’d need codes read to ascertain exactly what the problem is but as the wheel sensors record wheel revolutions then it maybe suggests one of those as obviously on a bend some wheels turn faster than others
- pvr
If I remember well you are not too far from me? I have a code reader
Current:
Abarth 595 Comp.
VW ID.3
Previous:
Z4 3.0 Toledo
Abarth 595 Comp.
VW ID.3
Previous:
Z4 3.0 Toledo
- RickRob
Thanks for the offer PVR.
My alternator failed yesterday, producing more lights than a Jean Michelle Jarre concert! Prior to that the 4 warning lights didn’t show themselves.
Being an optimist I am hoping that the new alternator will sort things out. If not I may well take you up on your kind offer.
Thanks for the advice chaps.
