Yea, it seems like the seatbelt retractor hole is directly ported to the wheel well.
Excessive road noise on passenger side.
Well I got to the bottom of the excessive noise problem. Apparently the rear tires are cupped on the inside edge, the right rear wheel is bent and the differential is worn and leaking. At this point I'm planning to just buy a new rear differential for $2000 and have an indie install it. In the mean time I'll find a 2nd hand wheel before replacing the rear tires.
- B21
javis20 wrote: ↑Wed May 03, 2023 1:11 am Well I got to the bottom of the excessive noise problem. Apparently the rear tires are cupped on the inside edge, the right rear wheel is bent and the differential is worn and leaking. At this point I'm planning to just buy a new rear differential for $2000 and have an indie install it. In the mean time I'll find a 2nd hand wheel before replacing the rear tires.
Quite a combo
Maybe get a second hand diff and get a LSD put in for the same money ?
What's an LSD?
- Chippie
Not sure man, think it’s something from the 60’s
Limited slip differential
I'm trying to decide between buying a new differential ($2050) or picking up a used one for $550. The used one has 39k miles on it. Any advise?
- B21
What model E89 do you have ?
2011 z4 auto trans. 3.0i. Differential part number 33107576667. Basically wondering if these differentials are problematic and a used one would also be destined to fail at 60k miles. If so, I would hold my nose and buy a new one.
Otherwise, it would be preferred to get a used one. Considering the indie shop found my rear right wheel bent, and both rear tires need to be replaced to pass july state inspection.
- B21
The diffs are usually pretty bulletproof…suggest you get a used one..check it on arrival and fill it with fresh oil
- Chippie
I suspect that at some point it’s had a whack on that right rear wheel, which has possibly damaged the gears in the diff and thrown the wheel alignment out.
- Christopher72
It's too expensive to fix on mine -- I will have to live with it. I checked the suspension, tyre, wheel, bearing, seat belt, trim, differential, brakes, etc. After replacing everything with new parts, lube and such... Still the noise. It's driving me crazy but like Tinnitus, it probably can be ignored as background noise if you work at it. So, I checked into my doctor for a medication solution. He told me that my hearing was fine.
So I tried to think outside-of-the-box... and the noise origination started to become clear. After that moment of clarity, I almost wept in despair. This wasn't something I could afford to fix -- It's not something that can be ordered from Germany or Latvia. I realized that the noise originates from my wife commenting from the passenger seat that I focus too much on the car. And she's too expensive to replace....
Christopher
2011 E89 Sdrive35i - Deep Sea Blue, Beige Kansas Leather
'fits in progress - PDC, Cameras, Comfort Access, Respray/Correction - all queued for poor weather.
(9) E46 convertibles; (1) E39 540i; (2) E36 Z3 roadsters; (1) Pre-prod E36 Z3- all gone
Well I found a 2nd hand differential (39k miles) for $530 and had it installed for $470. Fixed the differential noise problem. Now I'm just dealing with bent rear right wheel and inside edge tire wear.
As it’s had a heavy impact on the rear wheel the suspension may be affected so get 4 wheel tracking done when you have a new wheel and tyre
Yes, I plan to do that. Lowest price I can find for the wheel is $480 shipped and about $525 for 2 rear tires. Then add mounting, balancing and alignment. Ouch
Well yesterday I pulled the problem wheel because I wanted to have a closer look at the wheel liner (since I plan to add sound deadening to it). Anyway, with the wheel removed I got the idea to take it to a tire specialty shop to get their opinion. As I rolled the tire in, the guys in the shop said "hey there's something wrong with that tire". "It rolls like it has a damaged cord". When they put it on their balancing machine, the wheel was very distorted. As he spin the wheel the radius was off by about 10mm from low to high point.
Very disappointed with BMW dealer. I had them put brand new tires on the car a little more than 2 years ago. I thought the cars noisy ride would improve, it didn't. Assumed the tires were just noisy. Everyone said the ride would improve when I ditched the run flats. To make a long story short, I believe the dealer installed and did a 4 wheel alignment with a bent wheel. How could they not see the wheel was bent? When I ask them to diagnose the source of the noise, they identified the tires and differential. The differential was only about 15% of the noise. They would have again put tires on a bent wheel.
