Is a decat on a Z4M an option?
"M" Specific discussion
jontZ4M
Post by jontZ4M » Sun Mar 05, 2023 10:45 pm
Hi guys
I bought my Z4M roadster a couple of months ago and have been busy sorting out various bits with it. My next job is to tackle the exhaust. Currently the headers are on the car, but the rest is removed.
The exhaust is completely OE. It works but has two problems: 1) it's got a few blows 2) it's too quiet in general.
On examination the blows seem to be from the welds just before the cats. I see black sooting there.
My natural instinct at this point would be to replace this section with aftermarket decat pipes. This would fix the blows and from my experience with 90's Jap cars, increase sound without going over the top.
I come from Skylines and Silvias, and the internet is crawling with £100 decats for them. You just fit them and they never cause a problem(obviously reversion required for MOTs). But with the Z4M I can find almost no decat solutions for it. Do we know why this is? Is it because there are sensors in the cats and this causes problems with the electronics, making it impossible?
What are you guy's experiences with this please?
buzyg
Post by buzyg » Sun Mar 05, 2023 11:07 pm
I kept mine OEM and had inserts fitted to fix the joint problem that occurs at that point of the OEM Exhaust. Always sounded OK to me. But never a patch on the 5 pot burble of my previous Fiat Coupe.
jontZ4M
Post by jontZ4M » Sun Mar 05, 2023 11:12 pm
buzyg wrote: Sun Mar 05, 2023 11:07 pm I kept mine OEM and had inserts fitted to fix the joint problem that occurs at that point of the OEM Exhaust. Always sounded OK to me. But never a patch on the 5 pot burble of my previous Fiat Coupe.
Did these inserts cover the welded section like a sleeve? Or were they cut into the pipe?
Vanne
Post by Vanne » Sun Mar 05, 2023 11:58 pm
lots of decat options for z4m, just not for 100 pounds..
https://www.hackengineering.co.uk/produ ... ipes-z4-m/
Powered by Severn Tuning
buzyg
Post by buzyg » Mon Mar 06, 2023 1:45 am
jontZ4M wrote: Sun Mar 05, 2023 11:12 pm
They inserter sleeves inside. So that the inserts matched the original pipe width and didn't restrict flow. The pipes were eased out to a slightly larger diameter to accommodate them.
hiltonfa
Post by hiltonfa » Mon Mar 06, 2023 9:55 am
Had mine removed and straight piped very similar to the Hack Engineering pipes above, the rasp was terrible. Had to then have new silencers made up to deal with the rasp, the car is loud and does have some drone at certain RPM. Overall I'm very happy with the end result, my butt dyno tells me the car feels stronger :D I live in South Africa so don't have to worry about MOT.
Argenta
Post by Argenta » Mon Mar 06, 2023 10:54 am
Can't see the point really, unless you're after poisonous gasses? Which of course could be fun as a joke. If you have a weird sense of humour.
jontZ4M
Post by jontZ4M » Mon Mar 06, 2023 12:20 pm
Thanks for opinions guys
So options so far seem to be:
1 - re-weld the leaking welds myself (probably won't hold for long). Do we know if the OE steel is 304 grade SS?
2 - get a pro metal worker to add the sleeve sections as you guys have described.
3 - get a new decat pipe for £900 and deal with changing back to OE for MOT.
4 - replacing with OE is not an option, I checked with BMW and no longer available. And anyway it would be well over £2000.
hmmm
Ed Doe
Post by Ed Doe » Mon Mar 06, 2023 12:48 pm
Vanne wrote: Sun Mar 05, 2023 11:58 pm lots of decat options for z4m, just not for 100 pounds..
That price is absolute f*cking robbery for a pair of pipes!!!
Carbon Black '07 M Coupe: Intrax 1k2 Coilovers, AP-Racing, Raybestos ST45s, Tillets, Schroth, Vibratechnic, Apex EC7, Strongstrut, Eventuri, H&S, RTD, 4.1FD :evil:
Silver Grey '06 3.0si Coupe - SOLD :(
TomK
Post by TomK » Mon Mar 06, 2023 1:39 pm
viewtopic.php?t=138219
See Martyn's solution about half way down page 1
maupineda
Post by maupineda » Mon Mar 06, 2023 6:19 pm
Dont do decat. Car will sound horrible and smell like 💩 crap. You gain 2-5 hp, not worth it. Just repair the welds and move on. If you want more noise remove the resonator first. Or get a set of louder mufflers.
My car with SS x-pipe and remus was loud as f*k
Mikey_Boy
Post by Mikey_Boy » Mon Mar 06, 2023 9:23 pm
^^^ This.
Decat is an awful option. I bought a new OEM catalyst last year after a brick came loose after 14 years… It flows pretty well. Speak to Cheltenham BMW as they do them on an exchange basis - comes in a lot cheaper if I recall.
For the right noise, go for Supersprint or Remus or another established manufacturer. Loud exhausts are great until they get on your pecks, then they’re just annoying… :poke:
jontZ4M
Post by jontZ4M » Tue Mar 07, 2023 5:58 pm
TomK wrote: Mon Mar 06, 2023 1:39 pm See Martyn's solution about half way down page 1
Very clever, so he used E46 cheaper pipes and modified them. Probably above my skill level.
maupineda wrote: Mon Mar 06, 2023 6:19 pm Dont do decat. Car will sound horrible and smell like 💩 crap. You gain 2-5 hp, not worth it. Just repair the welds and move on. If you want more noise remove the resonator first. Or get a set of louder mufflers.
This car has a resonator? Where is it please? Is it that bulge where the two pipes meet? I thought that was just a joiner section.
So far repairing the Cat section seems best solution, then modifying it downstream for extra sound.
TomK
Post by TomK » Tue Mar 07, 2023 8:10 pm
jontZ4M wrote: Tue Mar 07, 2023 5:58 pm This car has a resonator? Where is it please? Is it that bulge where the two pipes meet? I thought that was just a joiner section.
Yes, where the 'X' is. I put a supersprint x-pipe on mine (already had their fairly loud 'race' back boxes) and the volume change was pretty extreme, I think my car went from measuring ~92dB @5000rpm to ~98dB static. Had to go back to stock for track day compliance, but I was happy, it was far too loud with the SS X-pipe. I have stock cats btw.
Vanne
Post by Vanne » Wed Mar 08, 2023 12:54 pm
Ed Doe wrote: Mon Mar 06, 2023 12:48 pm
yep, i didnt say it was a good deal, just that there are options out there.. :thumbsup:
