Airbags
- davewuyts
Airbags
This is epic. The most helpful forum since the dawn of civilisation! I won’t have time to look at this till next week but I will let you all know. We have something else under the carpet to sort out first as well. But I’ll get there!
- colb
Airbags
Looking at what module is exchangable with his 65776933985 SBSL bigwins module 65776928571 SBSL will be exchangable retrospectively and was fitted to cars from 25/11/2003 - 11/7/2003 according to Realoem parts site.
Z Shed Cymru member
1999 1.8 Z3
2003 2.5 Z4
1998 Honda Deauville 650
1999 1.8 Z3
2003 2.5 Z4
- davewuyts
Airbags
I'm going to need to replace my module - light still stays on and the same 1 fault shows up. This is the detail from Real OEM. Can anyone supply me with just the 65776933985 module?
Sensor, B-pillar left
05/15/2003
To:
05/17/2004 (ENDED
Weight:
187.300 kg
Part 65776933985 was found on the following vehicles:
Z4 E85 (04/2002 — 11/2005)
Superseded by:
65776948087
(03/18/2004 —), Exchangeable retrospectively
Supersedes:
65776928571
(11/25/2002 — 07/11/2003), Exchangeable retrospectively
65776928520
(09/02/2002 — 07/01/2002), Exchangeable retrospectively
65776926784
(09/02/2002 — 05/22/2002), Exchangeable retrospectively
65776926782
(09/02/2002 — 04/23/2002), Exchangeable retrospectively
65776924604
(09/02/2002 — 03/18/2002)
05/15/2003
To:
05/17/2004 (ENDED
Weight:
187.300 kg
Superseded by:
65776948087
Supersedes:
65776928571
65776928520
65776926784
65776926782
65776924604
- enuff_zed
Airbags
PM bigwinn, as suggested above, he has a compatible one.davewuyts wrote: ↑Wed Mar 15, 2023 11:57 am I'm going to need to replace my module - light still stays on and the same 1 fault shows up. This is the detail from Real OEM. Can anyone supply me with just the 65776933985 module?
05/15/2003
To:
05/17/2004 (ENDED
Weight:
187.300 kg
Superseded by:
65776948087
Supersedes:
65776928571
65776928520
65776926784
65776926782
65776924604
Onlinebigwinn
Airbags
Replieddavewuyts wrote: ↑Wed Mar 15, 2023 11:57 am I'm going to need to replace my module - light still stays on and the same 1 fault shows up. This is the detail from Real OEM. Can anyone supply me with just the 65776933985 module?
05/15/2003
To:
05/17/2004 (ENDED
Weight:
187.300 kg
Superseded by:
65776948087
Supersedes:
65776928571
65776928520
65776926784
65776926782
65776924604
EWS Delete PM me
Coding- airbags etc PM me
EWS Delete PM me
- colb
Airbags
Had another session on Daves airbag problems today, he had fitted another used compatable main airbag module so an initial Health Report scan was made first using the Launch Tablet. This revealed a few issues with the module codes suggested that the passenger airbag had been fired which would mean module is locked up. No chance of coding this module to Daves car so it gets the correct Vin number. Tried this a number of times but it came back with communication error. The right satellite module was also comming up with no communication, the left satellite module could be seen but wouldn't code to change the Vin number in that.
Every module Dave has aquired so far have proved duff and won't code to his car.
A new code pertaining to the left seat belt tensioner low resistance also made an appearance for the first time in this sorry saga, thats on thre back burner as the main and right satellite modules are the main bone of contention and need to be fixed.
Finding a servicable module is very difficult all Dave manages to get hold off are proving duff and uncodable.
Seems we need a complete set of modules from a car that has no codes set in order to start afresh. If a set can be found we would expect each module to set Wrong Vin codes when fitted to Daves car, then we may be able to change the Vin in each of them.
This is the most frustrating set of fauilts I have ever encountered, just hate not sorting it.
Z Shed Cymru member
1999 1.8 Z3
2003 2.5 Z4
1999 1.8 Z3
2003 2.5 Z4
- enuff_zed
Airbags
I know it means a wait but end of this month I’m going to break my old 4-pot.
It has no airbag codes and if all three have compatible numbers then I’m happy to send them all together.
Sorry I can’t do it sooner but I’ll put Dave’s name on the list for now.
Hopefully you’ll find something sooner but if not let me know.
MOT expires 27th so available straight after that
- colb
Airbags
Not at all sure about the fibre optic cable and its actual function I have always thought they communicate through the wires and am presuming if the main module is faulty that the cause of non communication errors with the satellite modules although Daves is showing an error with his rightsatellite module and the passenger seat belt pre tensioner which I believe are addittional faults to the main module issue.
Z Shed Cymru member
1999 1.8 Z3
2003 2.5 Z4
1999 1.8 Z3
2003 2.5 Z4
- colb
Airbags
Latest Launch report on 14/06/2023 with latest replacement module fitted
- Screenshot 2023-06-15 at 12-20-01 Inspection Report Daves.png (51.13 KiB) Viewed 339 times
Z Shed Cymru member
1999 1.8 Z3
2003 2.5 Z4
1999 1.8 Z3
2003 2.5 Z4
- davewuyts
Airbags
The thing is, several of these faults did not show up when previous modules I bought were loaded. I think there is confusion in the communication. Is it easy to replace the coaxial cable and can that make a difference?
I mean fibre-optic cable! If it's easy to remove it's worth it i think.
- colb
Airbags
Found this explanantion of the function of fibre optic cables
https://www.cartechnology.co.uk/showthr ... ?tid=31057
Not conviced there is anything wrong with Daves Fibre optics its seem to me we get different codes comming up as a result of the condition of the respective modules we have tried in the car, each one has various codes that were obviously set in the doner car.
Z Shed Cymru member
1999 1.8 Z3
2003 2.5 Z4
1999 1.8 Z3
2003 2.5 Z4
- enuff_zed
Airbags
Ok well hopefully you’ll be sorted before then but if not, and assuming they are compatible, I will do a full code check of all three and send them together. But will be a couple more weeks I’m afraidcolb wrote: ↑Thu Jun 15, 2023 7:56 pm Found this explanantion of the function of fibre optic cables
