How to remove interlock cable from steering column
In the process of getting my steering column out.
On the last cable, the interlock, but no idea the correct way to go about removing it.
Does anyone know the procedure?
- 1675517789029662567254030404030.jpg (128.73 KiB) Viewed 396 times
- bigwinn
Never seen that
Assume it’s auto box?
I’ve only dealt with manual car columns
EWS Delete PM me
Coding- airbags etc PM me
EWS Delete PM me
From pictures of replacements, looks like it just unscrews on the silver/gold bit, will go find a tiny spanner
I need to replace mine.. Any help where this is and what do I have to remove? I assume it goes into steering column some where and down to the automatic shifter? Is this easy access? Thanks
- enuff_zed
Do you mean column replacement or just the cable?
If it’s the column then just unscrew the cable from behind the ignition switch.
Just the cable . But I have no clue where it starts and whee it ends. Do I need to take apart the ignition? Where does it get connected to in the shifter area? How much is involved? Thanks
- enuff_zed
It unscrews from behind the ignition barrel but no idea where the other end goes. Sorry.
- enuff_zed
Not my photo, but if you take the lower steering column shroud off then look up from underneath you will see the cable attaches on the right side just a bit lower down than where the the key goes into the barrel
- DMike
Hi,
Never done it myself, but in TIS two documents, 32 32 170 and 25 16 175 explain the procedure to change and adjust the cable. Won’t post copyrighted material on the site, but maybe you can find them. Too complicated to describe in written, you need the pictures in TIS.
2005 Z4 3.0i Sterling grey
Thanks. I only need to tighten cable ...Can you tell me this or send me info? That would be great!!!!DMike wrote: ↑Sun Dec 31, 2023 11:47 pm Hi,
Also what is TIS? where can I get this as I only need to adjust cable.ThanksDMike wrote: ↑Sun Dec 31, 2023 11:47 pm Hi,
- DMike
Technical Information System, BMW’s acronym for their technical documents. They are copyrighted material so won’t post any links on the forum.V Vette wrote: ↑Mon Jan 01, 2024 7:30 pmAlso what is TIS? where can I get this as I only need to adjust cable.ThanksDMike wrote: ↑Sun Dec 31, 2023 11:47 pm Hi,
