Wheel spacers e85
Wheel spacers e85
Hi all .Thinking of putting wheel spacers on my e85 with standard wheels. Was thinking of 25mm. Anyone thinkk thats to much or envisage any proplems ?
Stirling grey 3.0 bog standard apart from DLV back box
- enuff_zed
Wheel spacers e85
With standard wheels I have put 20 on the back but nothing on the front and to me that looks about right
E89 20i SDrive M Sport - mine
E85 2.5i auto - Vall's
E85 2.0i facelift - Rescued as a winter daily
E85 3.0i manual - Project Cheapskate
E85 3.0i auto - gone
E85 2.5si - gone
E85 2.2i - gone
E85 2.5si - gone
E85 2.2i - gone
Online
Wheel spacers e85
I have 20mm on the back with an 8” wheel. 25mm with a 8.5” wheel would be too much unless you like the Carlos Fandango look.
I have 15mm on the front which I think is right looks-wise, but I do get some rubbing under compression between the outer edge of the tyre and the wheel arch liner.
Zedless for a day - back in a E85 Maldives Blue 3.0 fully loaded
- Chris_D
Wheel spacers e85
+1 for this config.
I have the same and found turn-in at slower speeds under acceleration slightly keener (which I like).
20mm already helps get rid of that in-board wheel look and I think you could probably get away with 25mm at a push.
Spacers on the front do nothing beneficial for handling and just causes rubbing.
Wheel spacers e85
I ran those wheels with 10mm front spacers and had no rubbing.Zedebee wrote: ↑Wed Jan 25, 2023 9:53 am I have 20mm on the back with an 8” wheel. 25mm with a 8.5” wheel would be too much unless you like the Carlos Fandango look.
- TheDan
Wheel spacers e85
On standard offset 18" staggered wheels (18x8 ET47 front and 18x8.5 ET50 rear) I think 12-15mm front and 15-20mm rear is the sweet spot. I currently have 12mm all round but I would like to switch to 15/20mm rear.
- enuff_zed
Wheel spacers e85
I think that there is a definite difference here between handling and pure aesthetics.
So whilst the consensus seems to be leaning towards 20mm on the rear, the front comes down to whether you want it look good at the possible slight expense of handling and to a very small degree, increased load on the suspension, bearings etc. (This is always quoted as an issue and basic physics means it must make a difference, but unless you go really wide I doubt it has a huge effect on component wear)
I did stick some 10mm on the front at the same time as I put 20mm on the rear, but I felt it made the handling less precise, with less feedback and more likely to follow ruts in the road. This is a personal opinion though. Others will differ.
E85 2.5si - gone
E85 2.2i - gone
E85 2.5si - gone
E85 2.2i - gone
Wheel spacers e85
Putting spacers on the front is almost always detrimental to handling. It alters the scrub radius, promoting toe-out under acceleration which contributes to tramlining and less predictability in hard cornering.
Albeit 98% of drivers in 98% of situations won't notice the difference.
Wheel spacers e85
Many thanks everyone . Bill
Online
Wheel spacers e85
Insurance companies really don't like wheel spacers, from what I have gleaned on multiple forums. There are reasons for that.
Spacers increase the track by the spacer width times two. You immediately alter all manner of physics; suspension geometry, weight bearing, etc.
It's worth bearing in mind IMHO.
All good things come to those who wait. But I'm really impatient which explains a lot.
F33 440i MPPSK and a bit of bling
E89. N20 with a cheeky remap
Mazda3 for the wifey and carrying anything. Underrated and underpowered
- Sidewaze Samm
Wheel spacers e85
When I bought my current zed, it was fitted with the same sized spacers as this. Felt just as Enuff has mentioned, so the front ones came off - and transformed the steering feel. (I kept the 20mm on the back though, as it does look better).
2008 3.0si E85
Space Grey, Dream Red New England heated Msports.
Xenons, MFSW, cruise, PDC, wind deflector.
ZHP, stubby, DLV box, gaptech, no CDV.
