Interior Décor
Interior Décor
Can anyone point me in the direction for a how too with regards removing the Interior Décor plastic from inside the car.. Looking a bit tatty and scratched in a couple of places.
2010 Black E89 35i
- Deepseaskateboard
Interior Décor
Post a couple of pictures, there will be different guides for different trim parts. Alternatively, you may be able to recolour like you can with the leather parts.
Interior Décor
I think I will end up taking them all off and spray piano black.Deepseaskateboard wrote: ↑Tue Jan 24, 2023 6:13 pm Post a couple of pictures, there will be different guides for different trim parts. Alternatively, you may be able to recolour like you can with the leather parts.
2010 Black E89 35i
Interior Décor
See this video on how to remove the interior dash trims:
https://www.youtube.com/watch?v=TQA3VtDh9AA&t=941s
Interior Décor
All the vids seem to be about removing the whole thing. Its just the Silver bits I would like to remove without taking it all to bits if possible.
2010 Black E89 35i
Interior Décor
Alas it's not that easy.Gingerlomax wrote: ↑Fri Feb 10, 2023 4:13 pm Capture.PNG
You have to remove the complete air-con panel from the side of the steering wheel cowl to the door.
Right side panel, take off the plastic trim at the side between the dash and door, remove one screw inside and then clip off the light switch panel.
To actually remove the silver trims you have to drill out the plastic weld studs, being very careful not to go all the way through. The reverse of this is that you'll have to glue them back together once you've finished what you are doing. I used apoxy glue to acheive a really good bond.
As for the silver door caps, jump to 08:05 on this video and I show how to remove the door cards. Then it's a couple of screws to remove to release the silver trims.
https://www.youtube.com/watch?v=CQVyPZQuB9U
Hope that helps.
Dave
2011, 23i, Grey with Red leather.
- B21
Interior Décor
I’m changing my trim…enjoy
- 37AA3FF5-72A6-4F54-A2EA-26D30311A38A.jpeg (202.11 KiB) Viewed 397 times
Interior Décor
To be fair I originally had all silver, then I bought some half leather (one was a brushed alloy which had seen better days and the other was a silver carbon) and wrapped the silver parts in a gloss black. Now this lasted about a year and I wasn't happy with it so I removed the gloss black and fitted a brushed grey, which lasted about six months. Then I removed the "new" silver parts and fitted my original solid silver sections into the half leather parts, also removing the wrap from the door cars sections and the centre console, and that's how it's now staying A nice standard factory colour combo
It's a lot of work, depending what you want to acheive.
Dave
- enuff_zed
Interior Décor
- Nictrix
Interior Décor
If you are ever doing this again you can melt the tabs holding the parts together with a soldering iron and reshape them enough to seperate them. Then when putting them back together you can use the soldering iron again to remelt the tabs to hold the two parts together.AnubisZed wrote: ↑Fri Feb 10, 2023 4:51 pm To actually remove the silver trims you have to drill out the plastic weld studs, being very careful not to go all the way through. The reverse of this is that you'll have to glue them back together once you've finished what you are doing. I used apoxy glue to acheive a really good bond.
- B21
Interior Décor
Good to know when I go for gold leaf next time ….Nictrix wrote: ↑Fri Feb 10, 2023 8:20 pmIf you are ever doing this again you can melt the tabs holding the parts together with a soldering iron and reshape them enough to seperate them. Then when putting them back together you can use the soldering iron again to remelt the tabs to hold the two parts together.AnubisZed wrote: ↑Fri Feb 10, 2023 4:51 pm To actually remove the silver trims you have to drill out the plastic weld studs, being very careful not to go all the way through. The reverse of this is that you'll have to glue them back together once you've finished what you are doing. I used apoxy glue to acheive a really good bond.
- B21
Interior Décor
That’s my hat…actually I carry several as when I leave the ground on bumps and come out of my seat I lose the current hat…usually there’s a board behind me that runs over it / renders it useless as they run over it
- spitfun
Interior Décor
I just did the center console to start in my car,that's where all my scratches were. I may do the rest eventually... I had mine hydrodipped and I replaced any worn buttons while it was out (picked them up on AliExpress)...
- 20230210_113814.jpg (214.18 KiB) Viewed 253 times
2012 Z4 Sdrive35i M Sport manual
