Anyone else had this?
Courtesy lights only seem to stay on for a few seconds after a door has been opened - I'm sure they used to stay on for much longer - and I can't see any way to change this in the menu
When I pull the key they seem to operate as they should
Also sometimes if I try and put the dome light on when driving it refuses to come on at all
Interior courtesy light problem
Z4 ‘13 20i Mineral Grey
Z4 '07 2.5Si Montego Blue
- enuff_zed
Probably an issue in the light unit itself.
I'd suggest a straight swap over as they're not very expensive to find.
I have a poverty spec spare, but if you need the map lights version then try bigwinn, street or umfaan.
