Z4 Aerial
Z4 Aerial
Hi all,
After a bit of advice!
Is the aerial in the attached picture a standard fitment?
If so, is the top part supposed to screw off? I've tried all my brute force but it doesnt unscrew.
Reason I ask is because I have purchased a car cover and it gets in the way somewhat!
- Z4 Aerial.jpg (169.33 KiB) Viewed 439 times
- bigwinn
Z4 Aerial
Get some wd40 in there they do like to seize up
If you do snap it off I’ve got spares it’s a fairly easy replacement
EWS Delete PM me
Coding- airbags etc PM me
EWS Delete PM me
Z4 Aerial
that, sir, is the original whippy aerial. if you do get it off, a dab of copper grease when you screw it back in again will help prevent future seizing.
Z4 Aerial
You will need a T25 when I mean if you break it had exactly the same thing I noticed the previous owner had a go as well could see the plier marks on the Ariel I soaked it for days and it still snapped I ordered a cheap stubby off eBay and a original base plate
Z4 Aerial
Thanksbrillomaster wrote: ↑Tue Jan 17, 2023 3:58 pm that, sir, is the original whippy aerial. if you do get it off, a dab of copper grease when you screw it back in again will help prevent future seizing.
Z4 Aerial
As above, put a dab of copper grease on the threads when you fit it again.
And it's the best aerial for the classic, Z4
Don't fit a silly stumpy
Toyota MR2 NA 1995
Triumph GT6 1972 (project)
Mini 1000 1981
Toyota MR2 NA 1995
Mini 1000 1981
