Valve cover bolt wont budge - E86
Just a small tip, WD40 is NOT a penetrating oil but a reasonably poor lubricant and whatever else it claims to be.
Make your own penetrating oil using 50/50 ATF / Acetone, even thinning down engine oil with diesel works but I prefer the first one.
Silver M Roadster
220d Active Tourer
Landrovers 90 & 110
220d Active Tourer
Landrovers 90 & 110
Online1536Z4
Did try something similiar but with an allen key banged into a hole drilled into the head before it came off and some superglue . Left it overnight and turned it next day but it just broke off . I don`t have a welder but a neighbour does so may ended up trying that . Thanks
Montego Blue E86 . MILV`s . Simpson Custom Manifold Race Exhaust . xHP transmission stage 3 . VT engine mounts . BC RA coilovers . H&R arbs . Adjustable rear camber arms . Ultra Racing front strut brace . Drexler LSD .
Online1536Z4
I`m actually using Plusgas but will bear it in mind
Online1536Z4
All good advice . Thank youDevonPaul wrote: ↑Fri Jan 20, 2023 11:58 am if you can part thread a nut to the remaining stud, then tack weld it. Lots of heating, spraying, and tapping the end with a small hammer when hot and cold.
I've done this in the past with bike exhaust studs.
If you end up drilling it out try and use a 90 degree bit holder and come in from underneath - that way the swarf goes away from the engine
OnlineMr Tidy
I'm not sure welding is the answer as those bolts on the N52 engine are aluminium IIRC.
Useless trivia - WD40 got it's name from being "Water Displacement, 40th attempt"!
Coupes because stunning!
Gone - Montego Blue
Gone - Ruby Black
Gone - Montego Blue
Gone - Ruby Black
Online1536Z4
I have now got most of the jobs done I wanted to so will be attemp to remove the pesky bolt tomorrow . I will update my progress . Thank you to everyone for your time and advice .
Online1536Z4
Hi Mr Tidy . They were aluminium on the magnesium cover I believe but steel for the plastic cover Definiteley steel on mine .
OnlineMr Tidy
That's probably why it is putting up such a fight!
Gone - Montego Blue
Gone - Ruby Black
Gone - Montego Blue
Gone - Ruby Black
Online1536Z4
Ok well finally got it out today with the help of a neighbour and his tig welder . He welded a nut onto the bolt and we both reckon it was the heat that did it as none of the previous options worked . Anyway I can get everything back together again as I have a replacement bolt ready to go.
Thanks again for everyones input
- thumbnail.jpg (108.92 KiB) Viewed 292 times
OnlineMr Tidy
Good to know you got there in the end!
Gone - Montego Blue
Gone - Ruby Black
Gone - Montego Blue
Gone - Ruby Black
And most importantly, you can use the bolt again.
Silver M Roadster
220d Active Tourer
Landrovers 90 & 110
220d Active Tourer
Landrovers 90 & 110
- Smartbear
Please tell me you’re joking
e85 3.0si sold
You must admit, the middle bit of that thread looks sort of ok-ish.
Silver M Roadster
220d Active Tourer
Landrovers 90 & 110
220d Active Tourer
Landrovers 90 & 110
Online1536Z4
I do like re using certain items but as I have a replacement bolt maybe not this time
- Smartbear
You’re right, i was expecting it to be corroded but apart from a burred thread at the end it looks as though it should have unscrewed ok
e85 3.0si sold
