Diagnostics fault codes
Blog is
Post by Blog is » Thu Jan 12, 2023 6:32 pm
Just before Christmas I had the classic 3 yellow warning lights (abs/dsc/handbrake). I got the diagnostics run which showed faults 5DF0 and 5DF1. So may need to go the ecu-testing route for abs/dsc hydro module repair. I have seen lots of threads on this forum about this.
It appears from members posts that the warnings can be triggered by various causes ie faulty pressure sensors/ steering angle sensor / wheel sensors etc etc. MY QUESTION IS - once diagnostics have come up with fault codes, are these reliable, ie do I take it that the abs pump IS faulty?
Any clarification appreciated.
patriot66
Post by patriot66 » Thu Jan 12, 2023 7:02 pm
I had exactly the same problem several years ago now. Sent the ABS pump to ECU Testing and it was fine. Fitted 2 new brake pressure sensors and no difference. Pulled all the wheel speed sensors and gave them and the reluctor rings a good clean...sorted ! No more warning lights. Cleared codes and all good since :thumbsup:
Mike6
Post by Mike6 » Fri Jan 13, 2023 7:06 pm
My money would be on the wheel speed sensors, very cheap to buy and easy to replace. I would bother cleaning them just peplace and get a very small brush through the hole and clean any dust off the reluctor rings.
