Mixing runflats with non runflats?
Thoughts or experiences of this?
Eventually I want to switch to non runflats but cant bear the thought or cost of binning 4 perfectly good runflats
However one rear tyre is soon on the way out
Do people mix runflats and non on the same axle or is that a bad idea?
I could just about stomach replacing both rears but not all 4 tyres at once
Z4 ‘13 20i Mineral Grey
Z4 '07 2.5Si Montego Blue
Online
Never mix different types of tyre,it will play havoc with handling. Change them all at the same time and discover how good your car feels. Don't forget some type of puncture repair kit and pump might now come in handy.
Silver M Roadster
220d Active Tourer
Landrovers 90 & 110
220d Active Tourer
Landrovers 90 & 110
- B21
You can never mix different designs on one axle, and the mixture of run flats and non runflats on different axles is prohibited in some countrires, which kind of points to it being a bad idea.
So its a no!
So its a no!
I had 2 new run flats fitted when I bought the car when I noticed that the rears weren't looking too clever so binned all 4 (the new one did around 2-3k.
If you're worried about cost, look out for deals from black circles, print it out then go to one of those chains that will match anyone's price (I did that with F1 autocentres and used a few vouchers to bring the price down a bit more).
You can possibly sell the "good" run flats on fleabay - although personally I'd never buy second hand tyres again (don't ask me why but michellin pilots at a "good price" resulted in a blow out and brown trousers)
To begin with, that's only 3 tyres. And, being runflats, they're not "perfectly good".jamesgarbett wrote: ↑Tue Jan 03, 2023 5:57 pm ... cant bear the thought or cost of binning 4 perfectly good runflats
So, do what Jasonn says. 'Proper' tyres will make your whole car better and you'll thank him for it.
Vidi, vici, veni
- enuff_zed
Just for giggles, fit non runflats on the rear only.
I'll guarantee you'll quickly be going back to get the fronts done.
(Or possibly just quickly going backwards )
- sars
It's all just hokum, Ideally you want the same make, model and size that your car was delivered with, that's what the car was developed with, anything else will give a slightly different driving experience, which may be better or worse in what is important to you.
Just make make sure you have the same make, model and size on each axle, obviously a different a tread pattern, size, compound or internal structure will give differing levels of grip, breaking efficiency, cornering ability, comfort and noise levels. In extremis, this could lead to an unpredictable driving experience especially when fitted on the same axle.
I don't understand why people put completely different sizes on their car and then state you can't put run flats on the front and normal tyres on the rear, changing make or model or size will alter your cars handling as will having extra load tyres or run flats
Gorgeous SFR Z4 M40i
Gone 2017 Iridium SL400, 2015 435d xDrive Convertible, 2012 E350 CDi Convertible, 2010 DSB Z4 sdrive30i, 2008 Audi A4 Cabriolet, 2006 Phoenix Yellow Z4 2.5Si, 2003 Saab 9-3 Convertible
i keep writing and rewriting a reply, but in short, i'm with sars. dont mix across the same axle, but happy to mix front to rear, as long as you are aware of the limitations. the main difference with run flats is a super stiff sidewall, which leads to a harsh ride and more tendency to tramline.
- Scubaregs
If it's not against the law it's personal choice. Personally I would not mix run flats on an axle with non run flats on the other.
not illegal just plain stupid.
G29 M30i M Sport San Francisco Red
Previous
E89 35is Valencia Orange
E89 28i Crimson
E89 25i White
Previous
E89 28i Crimson
E89 25i White
OnlineNictrix
I know its not a cheap thing to do but if you want to get the best out of your car a matching set of tyres is a good start.
In the past I have twice used either cheap tyres or mismatched tyres and have regretted it and will hopefully never do it again.
- Scubaregs
Unfortunately we cannot make stupidity illegal.
OnlineArgyll Andy
Otherwise Paisley would be empty and Barlinnie bursting at the seams
Oh and Happy New Year to you and Lynn
G29 M40i Thundernight with Ivory interior, all option packs (here for a while, hopefully )
E89 23i sDrive, Silver (Gone)
- sars
Is that a rational thought out response or just a gut feeling? For me it is exactly the same as increasing the tyre width or profile from a standard specification and so many on here are happy to do it.
- enuff_zed
sars, for me the whole issue with runflats is a 'seat of the pants' feeling.
I would suggest that possibly your pants are a lot smaller than mine and can't detect such small changes.
Right! That's it! No more inferred compliments until 2024.
