Vibration noise
Vibration noise
Hello to all. I'm the new kid on the block ok old man on the block. I've purchased a Z4 2003 3.0 130k auto So far I've replaced the Disa valve, cleaned the idle control valve, and waiting for a crankcase breather hose. At and only at 1750 rpm there is a vibration noise coming from behind engine only under power will not do it in neutral. Sounds like a really mad bumblebee. Any help would be appreciated.
- bigwinn
Vibration noise
Welcome!
May be difficult but try to record the sound
If it’s under load in that area it may be clutch/flywheel related but hard to say without hearing it
EWS Delete PM me
Coding- airbags etc PM me
EWS Delete PM me
- bigwinn
Vibration noise
I’ve had head shields work loose and corrode before
That’s worth a look especially at the one that sits drivers side (uk rhd car) side
EWS Delete PM me
EWS Delete PM me
Vibration noise
I'm not sure what a head shield is. Were is this located on the driver side?
- bigwinn
Vibration noise
You can’t miss it
It’s a bright silver aluminium shield that sits on the side of the engine where the exhausts are- check that’s not loose?
EWS Delete PM me
EWS Delete PM me
Vibration noise
Were left drive here in usa I'll check it thanks.
Vibration noise
Think it was meant to read heat shield
F31 320i. Good car.
E89 20i Now fully dried
Mazda3 sold
F31 320i. Good car.
Mazda3 sold
Vibration noise
If anyone has had this problem this is what I found. I replaced the passenger moter mount and no more noise.
