Energy costs (again)
Online
I have now started logging my gas and 'leccy usage from 1st to 1st of each month to see what it is actually costing, as the usage is rising.
November was not cold by any stretch, our house is fairly modern (2002), we have 100% LED light bulbs and fittings, all appliances are new and at least 'A' rated, modern condensing system boiler, three rooms in the house heating shut off and doors kept closed. Our heating is off during the night and most of the day. Only 3 people in the house. Heating thermostat set at 17 deg C. The tumble dryer has hardly seen any use yet.
There is not a lot more I can do to cut back. Our November costs (including standing charges and VAT) were £390.92.
That is outrageous!
Was paying 11p/ kWh for electric earlier in the year. Now 33p. 300% increase
Was paying 2.3p/ kWh for gas. Now 10.24p. 450% increase
That is outrageous!
F31 320i. Good car.
E89 20i Now fully dried
Mazda3 sold
F31 320i. Good car.
Mazda3 sold
- Stevo1987
Hmm..seems a lot my last statement was £350 but that was estimated. The real cost was about about £250. Only two of us here now in a 4 bed detached. Do you know what your average usage per day is for November it would be interesting to compare.
2014 Z4 e89 35is in mineral grey.
2012 Audi TTS in Ibis white.
- Smartbear
My electric use only has been averaging just under £90/month, we have an oil burning boiler for heating though so that’s another bill on top.
Had the central heating on for aprox 10 days now, before that we were just using our log burner
e85 3.0si sold
- Stevo1987
My electric use is similar.
- N4LLY
My November bill was £ 3.77 (After the £66 discount)
All electric, i have no gas.
- Nictrix
And yet all the energy companies are reporting record profits. Wonder why.
Online
Our electric was £100.98 (plus £13.73 standing charge), so it's mostly gas.
We have a gas hob and a gas 'stove' in the main living room. The house isn't very well insulated considering it is quite modern (cos the developers couldn't give a sh*t). 2500 sq ft house, so reasonable size.
I checked that the gas meter isn't letting-by; unfortunately it isn't.
I am at home all day, every day and will put the heating on if I'm cold. I ain't going to freeze!
BTW the figures are usage. Doesn't include the £66 grant. That is paid directly so doesn't impact on the bill.
F31 320i. Good car.
Mazda3 sold
F31 320i. Good car.
Mazda3 sold
Online
One light bulb and cook using a fag lighter I presume?
F31 320i. Good car.
Mazda3 sold
F31 320i. Good car.
Mazda3 sold
- Stevo1987
Again, your electric is similar to mine in a similar sized house and I wfh. Though, most weekends, I'm somewhere else these days. Induction hob and I tend to use the air fryer rather than using the oven.Pondrew wrote: ↑Thu Dec 01, 2022 3:00 pmOur electric was £100.98 (plus £13.73 standing charge), so it's mostly gas.
- Vornwend
I count myself luck to be paying 3.43p/KWh for gas - well until next August anyway. We are 3 in a 1990 4 bed detached, always occupied, with gas for central heating, water and and hob for cooking. Using around 40 - 50 KWh per day when its this cold often less if it's milder. You usage seems to be twice as high or more allowing for the price differential? We used to have hot water on a programmed schedule but now manually turn it on when needed, same with heating - don't know if that explains the difference? We had cavity wall insulation put in a few years ago and I think that has made a really big difference to our heating costs.Pondrew wrote: ↑Thu Dec 01, 2022 12:48 pm I have now started logging my gas and 'leccy usage from 1st to 1st of each month to see what it is actually costing, as the usage is rising.
That is outrageous!
Now: 2004 Z4 3.0i - Merlot Red
Before: VW Corrado VR6 Storm - Classic Green
- TitanTim
Currently on duel fuel fixed rate until the end of 2023 which I renewed last December so currently paying £64 gas and £78 for electric per month. This is based on my previous tariff usage and applied to my current tariff. I'm definitely using less gas compared to my old tariff yet my smart meter is telling me I'm going over my set budget each day now it's getting colder. I have the heating on for 1 hour in the morning, hour late afternoon and an hour last thing at night, heating is off over night and water is heated for 45 minutes per day so less than when i was on my previous tarrif. New boiler was fitted last Feb but I reckon its not really that more efficient than my previous 20 year old boiler. I might reduce the boilers flow output temp, currently on 70 degrees and might try 60 and see if it makes any savings. Tend to set thermostat to 19C. House has cavity wall insulation etc. I would be interested to get thermal camera and see how well the house is insulated.
I just have a feeling even though I'm on a fixed tariff around £1600 a year I'm being ripped off by British Gas somehow by massaging my usage to claw back any savings with me being on a fixed rate. I've become a little distrusting of British Gas of late.
Tim.
Tim.
Online
Our hot water is programmed to heat once per night; it takes about 15 mins (I have checked) and is never boosted. I am in the heating/cooling industry and have renewed/ improved everything that is practically possible on the heating system (bar ripping it out and starting again).Vornwend wrote: ↑Thu Dec 01, 2022 5:10 pm I count myself luck to be paying 3.43p/KWh for gas - well until next August anyway. We are 3 in a 1990 4 bed detached, always occupied, with gas for central heating, water and and hob for cooking. Using around 40 - 50 KWh per day when its this cold often less if it's milder. You usage seems to be twice as high or more allowing for the price differential? We used to have hot water on a programmed schedule but now manually turn it on when needed, same with heating - don't know if that explains the difference? We had cavity wall insulation put in a few years ago and I think that has made a really big difference to our heating costs.
Last 12 months cost me £1,500 for gas and leccy. The next 12 months is on track to be £4,200 on the same usage (less £400 of course).
F31 320i. Good car.
Mazda3 sold
F31 320i. Good car.
Mazda3 sold
- pvr
I don't have gas, but read that they are forcing oil boilers out by 2025 where you would have to install ground source heat. Estimated costs around £40k average so it seems.
Gas users have another 10 years till 2035, but only need to change if the cost is similar to gas. Not for oil users.
Current:
911-50 Black - unique spec
X5M - 575 hp of fun in a V8
Abarth 595 Comp.
Z4 3.0si Black Sapphire
VW ID.3
Previous:
Z4 3.0 Toledo
Abarth 595 Comp.
VW ID.3
Previous:
Z4 3.0 Toledo
- pvr
Oh, never got the £400 for elec nor the £100 for oil. Still not sorted out by Scottish Power.
Current:
Abarth 595 Comp.
VW ID.3
Previous:
Z4 3.0 Toledo
Abarth 595 Comp.
VW ID.3
Previous:
Z4 3.0 Toledo
- enuff_zed
Bloke at work on Tuesday was going on about it. He basically repeated the same thing to each individual in the office, over and over again.
After about 2 hours of this (seriously!) he got round to asking me what I thought.
I replied "Couldn't give a f**k mate, I'm loaded!"
I'm not, but it certainly shut him up.
