I'm not over reliant on the car so I'll order a new genuine part if it's cracked. I'll know more tomorrow, hopefully it holds enough to get through the MOT.
Tim's E85 3.0i in Sterling Grey
E85 2003 Z4 3.0i
- enuff_zed
I do yes, thanks anyway! I’ve also bought one on eBay before I knew there was two separate models.enuff_zed wrote: ↑Mon Dec 12, 2022 8:39 pmDo you have headlight washers? If not I have a washer bottle here
E85 2003 Z4 3.0i
MOT sorted for another year, and the washer wipe tank isn’t leaking (at the moment)
If any admin read this, feel free to move to E85 discussion. Thanks.
E85 2003 Z4 3.0i
- enuff_zed
I've had the same issue with one before where the headlight washer obviously hasn't quite closed off properly after operation and then emptied the tank. Happened once every other month or so until I got fed up and pulled the fuse!
That may be the issue, it was definitely frozen in the tank but then when I next checked it was empty and there was blue snow in front of the car. Refilled with proper concentrate stuff and all is well.
E85 2003 Z4 3.0i
Just to keep this updated,
Washer bottle seems fine, found water getting into the passenger side (as documented on another thread) so I’ve reseated the insulation to try and make it watertight. I’m sure I’ve done a temporary fix so will get the stuff ordered to do a proper fix in the spring.
Next up is the coolant bottle sensor and chucking in a new air filter for now.
I seem to be clearing one little job, only to find more stuff to do. But I’m enjoying tinkering with cars again!
Had quotes of £800+ to refurb wheels so we will see in spring what happens but they can stay as they are for now until all of the niggly jobs have been sorted.
E85 2003 Z4 3.0i
OnlineMr Tidy
A shame you keep finding things that need to be done, but at least you are enjoying tinkering!
I know 108s can be expensive to get refurbed, but £800 sound excessive!
You could probably buy a good set for less than that!
Coupes because stunning!
Gone - Montego Blue
Gone - Ruby Black
Gone - Montego Blue
Gone - Ruby Black
£889 to be exact, there’s a decent set on eBay for far less. Job for when all the niggles sorted.
E85 2003 Z4 3.0i
OnlineMr Tidy
That's why I fitted some 295s from an E89 to my 2nd Coupe and sold the 108s while they were still looking good!
Gone - Montego Blue
Gone - Ruby Black
Gone - Montego Blue
Gone - Ruby Black
- Chris_D
A cheaper option..?T_J_G wrote: ↑Sat Jan 07, 2023 5:31 pm Just to keep this updated,
viewtopic.php?t=136266
- Griffo46
Just buy these and sell yours for £100 on ebay and that'll save you 400 quid
https://www.ebay.co.uk/itm/125649324599 ... R4be-pGyYQ
2007 3.0si Roadster Stratus Grey/ Red Leather
2016 520d F10 M Sport Space Grey
Yup but I’d like to not paint over the bolts - I’m a bit fussy like that.Chris_D wrote: ↑Sun Jan 08, 2023 10:05 amA cheaper option..?T_J_G wrote: ↑Sat Jan 07, 2023 5:31 pm Just to keep this updated,
Yup when the time comes I’ll be going this route I think.Griffo46 wrote: ↑Sun Jan 08, 2023 12:26 pm Just buy these and sell yours for £100 on ebay and that'll save you 400 quid
E85 2003 Z4 3.0i
Thought I'd treat you all to a quick picture of a filthy car
E85 2003 Z4 3.0i
