Frozen out!
Busterboo
Frozen out!
Post by Busterboo » Fri Nov 25, 2022 2:19 am
All the rubbers need gummi pflege, anyway. If it stops the windows sticking, so much the better. If it doesn't, I don't know what will.
Vidi, vici, veni
MikeyH
Frozen out!
Post by MikeyH » Fri Nov 25, 2022 4:05 pm
On a Renault Megan’s cab my wife owned a few years ago I used vasoline and was promptly told off by a forum member. :oops: Not on here, didn’t have my zed then. :x Got more sense now :wink:
McHaggis69
Frozen out!
Post by McHaggis69 » Sun Nov 27, 2022 10:53 pm
Thanks all.
Have gummi pfledged all the rubbers (oo-er matron) and will see how that goes.
A half car cover sounds like it might be in order though if the lube doesn't help.
Never realised just how wonderful an underground garage had been at my last place - it never dropped below a few degrees above freezing.
2020-2023 E89 Z4 sDrive30iM Sport
2023-? G29 Z4 sDrive20i M Sport tech & comfort packs
N4LLY
Frozen out!
Post by N4LLY » Mon Nov 28, 2022 7:15 pm
Yep, underground garage is a blessing :)
2014 20 M sport Valencia Orange
MikeyH
Frozen out!
Post by MikeyH » Mon Nov 28, 2022 7:20 pm
Nice :thumbsup:
tonyg
Frozen out!
Post by tonyg » Thu Dec 08, 2022 7:47 pm
Yes my E89 froze out this morning and it was just -1 celcius ...we have another week of this in southern England! I have to say my very old E36 does this too and eventually it stopped my drivers door mini-dropping! I used to get Gummi- Pflege and it didn't help with the E36 but have tried it with my Z4 this evening - I suspect it'll have to be warm water in the morning again?!
MikeyH
Frozen out!
Post by MikeyH » Thu Dec 08, 2022 9:30 pm
After reading this Iv'e Gummi- Pflege my wife's Ford Focus CC as she has been using defroster spray :thumbsdown: around the window before trying to open the door as the windows drop a little.
wanderer
Frozen out!
Post by wanderer » Fri Dec 09, 2022 12:02 am
Was just reading this thread last week and didn't think it would be a problem for me as it wasn't last year.
But my battery died a few days ago and this evening I thought I would go out and jump start it.
But the key lock was frozen to begin with, so it would not even accept the key. The rest of the door was frozen as well.
Luckily the passengers side was unlocked and I managed to get it slightly open and then managed to tug it open with my fingers around the door frame.
Didn't help my original problem though because the Halfords brand booster would not jump start the car.
Now even the key is stuck in the ignition and won't release because the battery is deader than dead.
I would boost it with my 3 Series but could not find the cables in the dark.
Anyway, I noticed a Noco GB40 1000A booster on sale and ordered that instead.
Damned winter!
javis20
Frozen out!
Post by javis20 » Fri Dec 09, 2022 4:42 am
This happened to me several times. Usually I use a .010 " thick brass shim and insert and go around the edge to break the ice seal. Works pretty well.
DevonPaul
Frozen out!
Post by DevonPaul » Fri Dec 09, 2022 6:52 pm
MikeyH wrote: Tue Nov 22, 2022 12:11 am
buzyg wrote: Mon Nov 21, 2022 2:26 pm Simply move to a house with a nice snug warm garage. :wink:
Or move to the Westcountry, don’t get much frost in the Torbay area. :poke: :wink: :thumbsup:
Too many tourists in summer - at least they just drive past Buzyg's on the way to somewhere nicer :)
2006 Imola Z4MC (wife's shopping trolley)
1990 Toyota Carina (Started as a free family heirloom, now apparently a Classic)
2016 Toyota Avensis 1.6D (yup, the *really* slow one).
2011 TDM900
1997 VFR750 project. 95% complete. Only 30% left to do.
MikeyH
Frozen out!
Post by MikeyH » Fri Dec 09, 2022 7:14 pm
DevonPaul wrote: Fri Dec 09, 2022 6:52 pm
:rofl: :rofl: :thumbsup: :evil:
wanderer
Frozen out!
Post by wanderer » Fri Dec 09, 2022 7:54 pm
OK.
Right.
Great.
wanderer
Frozen out!
Post by wanderer » Sat Dec 10, 2022 3:28 pm
Got the Noco Boost Gb40.
Charged it fully and took it out to the car.
Systems powered on. Car attempted to start 3 times, almost did so and then the Noco was dead.
Eventually I hooked up my 3 Series, started the 3 series and waited.
Within a few minutes, the lights came on and dash powered up. Switched off the lights and aircon and waited 25 mins and then started.
Left it running about 1hr then drove it around the block and parked it closer and hooked up a charger. It showed 12.6 Volts, so that was reassuring.
Have left it on trickle charge.
Damn winter!!
javis20
Frozen out!
Post by javis20 » Fri Dec 23, 2022 11:41 pm
Well I decided to do a little experiment. A few week ago I applied gummy pledge all around the edges of my drivers door window and other rubber areas that freeze the door shut. I didn't do anything to the passenger door. As luck would have it, we are in the middle of a bomb cyclone. Current temperature is 8 degrees F. The passenger door is frozen shut. The gummy pledge drivers door is perfect.
Busterboo
Frozen out!
Post by Busterboo » Sat Dec 24, 2022 8:08 pm
javis20 wrote: Fri Dec 23, 2022 11:41 pm Well I decided to do a little experiment. A few week ago I applied gummy pledge all around the edges of my drivers door window and other rubber areas that freeze the door shut. I didn't do anything to the passenger door. As luck would have it, we are in the middle of a bomb cyclone. Current temperature is 8 degrees F. The passenger door is frozen shut. The gummy pledge drivers door is perfect.
Busterboo wrote: Fri Nov 25, 2022 2:19 am All the rubbers need gummi pflege, anyway. If it stops the windows sticking, so much the better. If it doesn't, I don't know what will.
:oops:
Vidi, vici, veni
