Mystery part-swaybar
- spitfun
I am looking for the name of this part. It connects to the swaybar on passenger side,I believe it stiffens the shocks up when you go into a hard corner to control roll. Mine seems loose and the arm is bent,I can't find it mentioned anywhere-anybody know what is is called??
2012 Z4 Sdrive35i M Sport manual
- Nictrix
- spitfun
Really? I thought it was weird it was only on one side... Thanks
- Nictrix
Im sure it is. The headlights automatically level.
Light reveler, if you accelerate the dipped light beam should move down.
- B21
There’s one on the front wishbone too
- Deepseaskateboard
100% headlight level sensor. Mine was snapped, BMW wanted over £300 to fix it!!
- smorris_12
Fwiw, they're also used to control the air suspension and ride height on X5s, 5er Tourings etc.
Scott
Where are we going and why am I in this handbasket?
2006 Z4 2.5si Silbergrau und rot
Scott
- B21
On the E89 the level sensors are just for headlight control…damping control is ‘sensed’ by 3 accelerometers onlysmorris_12 wrote: ↑Fri Nov 18, 2022 11:06 pm Fwiw, they're also used to control the air suspension and ride height on X5s, 5er Tourings etc.
