Thanks, I take it then if you were to swap the cluster for a few thousand miles and then put the original back in it would still show the correct mileage then, as in the updated mileage.
Digital Cluster
- Nictrix
Digital Cluster
- B21
Digital Cluster
Looking these babies up it appears that there are several tinted renditions of a ‘G29’ type display only…ie no ‘classical’ display variants…
- B1C8E24E-92D7-45F9-8E89-475D922C1362.jpeg (176.36 KiB) Viewed 953 times
- B21
Digital Cluster
That’s the theory…that’s what would happen if you installed a new BMW clusterNictrix wrote: ↑Sun Nov 13, 2022 11:15 pmThanks, I take it then if you were to swap the cluster for a few thousand miles and then put the original back in it would still show the correct mileage then, as in the updated mileage.
- Nictrix
Digital Cluster
B21 wrote: ↑Sun Nov 13, 2022 11:17 pmThat’s the theory…that’s what would happen if you ins
Online
Digital Cluster
Sorry guys, alas I have no further info at the moment.
I've not seen any other display options, and the mileage is, as stated above, stored in the CAS which transfers it to the cluster.
I will ask regarding swapping it back to stock about the tamper dot, as you wouldn't want that. But in theory as it still contains your VIN then it "should" be OK.
I'll try to get a video of one in actual use.
Dave
2011, 23i, Grey with Red leather.
- Christopher72
Digital Cluster
I just don't know how I'll realistically break my existing one to prove to my wife we need a new one...
Christopher
2011 E89 Sdrive35i - Deep Sea Blue, Beige Kansas Leather
'fits in progress - PDC, Cameras, Comfort Access, Respray/Correction - all queued for poor weather.
(9) E46 convertibles; (1) E39 540i; (2) E36 Z3 roadsters; (1) Pre-prod E36 Z3- all gone
- ProfCJJ
Digital Cluster
I would deffo be interested, especially if it allowed some customisation.
Online
Digital Cluster
OK some more info.....
Q - If someone wanted to swap back to their original cluster, would that still be possible without issue?
A - Yes, it`s no problem not change anything of OEM cluster
Q - Can you change the look of the cluster?
A - Yes, but need good quantity for custom the UI
Q - So it comes as one style from factory? Not changeable by customer later?
A - Yes can't change by customer latter, not allow customer change UI. Linux system,very stable, plug and play, I sold 100 pcs cluster 0 refund
Q - Do you have a video of one installed working showing it in use? Any BMW model
A - https://www.youtube.com/watch?v=hidmaE1GfM8
https://www.youtube.com/watch?v=Ux1XKRJFtIY
https://www.youtube.com/watch?v=SShA_7JV_A4
Q - One of those videos shows it to be a lcd panel and plastic front. I thought it was a all-in-one assembly that was identical to the original cluster.
Was the one in the video a pre production test one?
A - same as OEM, it's E90 with 2 part.
So there you have it. It is limited to the UI (clock style) that has been posted above, but you can have some individual set up within what is there.
Any specific questions then please post below and I'll pass these on.
Here's a few of mine that I'll send him tomorrow,
The M logo, can it be removed?
Is it changeable from KPH to MPH?
Will it display Cruise Control info?
Quite a few setting from the BC stalk are displayed and adjusted through the cluster, can these still be done this way?
When changing from Normal to Sport, to Sport+ will this be displayed on the screen, as it does now?
Dave
- B21
Digital Cluster
Thanks for the due diligence
- Nictrix
Digital Cluster
Looks good and so easy to change.
Things to change, TIRE, COLOR, STRATUP
The STRATUP instead of STARTUP I think would annoy me.
Online
Digital Cluster
They can't spell tyre or colour properly so start-up may be a step too far IMO
When I look at these 'modern' digital displays with the angled main instruments, I just think of old computer games.
There was a Car SOS where they did a Lotus Esprit and got a 'bespoke' digital display for it. I thought that was done in the UK?
F31 320i. Good car.
E89 20i Now fully dried
Mazda3 sold
F31 320i. Good car.
Mazda3 sold
- ProfCJJ
Digital Cluster
If it’s Linux based it might be “hackable” ….
- Marcoose
Digital Cluster
The tachometer seems to have the redline towards the top part. With my height and settings, the 60-80-100 mph readings are always blocked. I’d want to keep an eye on RPM.
2016 35is, monoballs, camber plates, KWV3, PS4S, xHP, MHD, LFB pedal, flat bottom wheel, red indicators, black headlamps
- ProfCJJ
Digital Cluster
Other questions worth asking: is it running Automotive Grade Linux, and what hardware/cpu is it running on?
I’ve been reading up on Linux in automotive applications and there are standards to do with “fail safe” etc - I wonder how much these standards have been adhered to??
- B21
Digital Cluster
ProfCJJ wrote: ↑Thu Nov 17, 2022 10:03 am Other questions worth asking: is it running Automotive Grade Linux, and what hardware/cpu is it running on?
I’m struggling to comprehend how some Chinese coders / copies of other peoples code will have done a structured assessment of likely failure modes and produced redundant code to ensure continuity….
Given the likely market size , the type of user I’d think there will be close to zippo chance of any relevant post product customisation..
All IMHO…
