Bosch Quality?
- N4LLY
- MikeyH
Bosch Quality?
- sars
Bosch Quality?
I would certainly send a complaint into Bosch, if one of their suppliers is cutting corners I’m sure they’d want to know. Also is it magnetic?MikeyH wrote: ↑Wed Nov 02, 2022 11:16 am Thank you for your replies, does your lid still flip up 1st go PerryGunn, ours doesn’t always now. Sometimes give up and use my finger in the spout. SARS this is definitely corrosion and brittle as can be seen from bits missing. We don’t need to de scale as we live in a soft water area. I wonder if it’s a Chinese Knock off.
Gorgeous SFR Z4 M40i
Gone 2017 Iridium SL400, 2015 435d xDrive Convertible, 2012 E350 CDi Convertible, 2010 DSB Z4 sdrive30i, 2008 Audi A4 Cabriolet, 2006 Phoenix Yellow Z4 2.5Si, 2003 Saab 9-3 Convertible
- N4LLY
Bosch Quality?
Wow, proper point and question
- MikeyH
Bosch Quality?
I don’t know if it’s magnetic, the wife has rung Bosch and they have said no one else has complained and would she send it to them. Goodbye evidence. TBO as we are in a soft water area we don’t really need it anyway. The same thing happened to her Bosch hair curlers, when some springs in them went rusty and they hadn’t in the old ones which were the same. I suspect it is like everything these days, companies are cutting corners and using cheaper goods and suppliers to cut costs.sars wrote: ↑Wed Nov 02, 2022 5:10 pmI would certainly send a complaint into Bosch, if one of their suppliers is cutting corners I’m sure they’d want to know. Also is it magnetic?MikeyH wrote: ↑Wed Nov 02, 2022 11:16 am Thank you for your replies, does your lid still flip up 1st go PerryGunn, ours doesn’t always now. Sometimes give up and use my finger in the spout. SARS this is definitely corrosion and brittle as can be seen from bits missing. We don’t need to de scale as we live in a soft water area. I wonder if it’s a Chinese Knock off.
- PerryGunn
Bosch Quality?
Always pops open when the kettle's cool or been left for a while after boiling. If you try to open it directly after boiling it can stick sometimes but I think this is due to steam condensing in the groove that the edge of the lid sits in - all of ours have been like this.
Alpina Roadster S #320
* Quaife ATB LSD * StrongStrut Braces * Turner RTAB Limiters * Gap-Tech RCH+ *
* Intravee & KCA-420i * Mini 0806 * Cheetah C550 * Stubby *
- MikeyH
Bosch Quality?
Normal then, it's just that when I find one thing wrong, I start noticing other things as well.PerryGunn wrote: ↑Wed Nov 02, 2022 6:24 pmAlways pops open when the kettle's cool or been left for a while after boiling. If you try to open it directly after boiling it can stick sometimes but I think this is due to steam condensing in the groove that the edge of the lid sits in - all of ours have been like this.
- PerryGunn
Bosch Quality?
The one thing I don't like about them is the 'beep' is far too loud so the first thing I do when we get a new one is to mod the base to reduce the beep volume - takes about 10 mins and doesn't cost a penny
- MikeyH
Bosch Quality?
How do you do that? Easy?
- PerryGunn
Bosch Quality?
Unplug it first - obviously
Pop the top off the base - use thin shims (I tend to use old butter knives as they're thin but wide), lever gently and it'll gradually pop out of the surround.
Once the top is off you'll see a small piezo speaker - looks like a small upright cylinder (all of mine have been black).
Most of the noise comes out the hole in the top so I stick some thick plastic over it - small round stick on feet/bumpers from various equipment purchases work really well.
Then reassemble using gentle pressure to 'pop' the top back into place
Easier to do than explain...
- pvr
Bosch Quality?
PerryGunn, holiday in Devon by the sounds of it then
Current:
911-50 Black - unique spec
X5M - 575 hp of fun in a V8
Abarth 595 Comp.
Z4 3.0si Black Sapphire
VW ID.3
Previous:
Z4 3.0 Toledo
Abarth 595 Comp.
VW ID.3
Previous:
Z4 3.0 Toledo
- MikeyH
Bosch Quality?
nice here when it’s not raining
- Smartbear
Bosch Quality?
This is by far the longest lived kettle I’ve ever owned, most seem to croak after a couple of years but this is still going strong past it’s 6 birthday - it’s probably doomed now I’ve mentioned it
Robe89 Sdrive 20i, plenty of mumbo & good economy-the thinking bears z4
e85 3.0si sold
Bosch Quality?
FFS. I can't believe it has come down to grown men taking photos of their kettles!
I don't know if we have a kettle; that's the wife's domain!
F31 320i. Good car.
E89 20i Now fully dried
Mazda3 sold
F31 320i. Good car.
Mazda3 sold
- TitanTim
Bosch Quality?
I have been resisting taking an arty shot of my Bosch Kettle but I do have a matching toaster and Tassimo in black
Using filtered water seems to make a big difference.
Of course after reading all of this I'm now kettle paranoid
Tim.
