Spring broken?
tiglon
Spring broken?
Post by tiglon » Fri Nov 11, 2022 3:40 pm
Argyll Andy wrote: Fri Nov 11, 2022 2:48 pm
tiglon wrote: Fri Nov 11, 2022 10:51 am
Busterboo wrote: Fri Nov 11, 2022 8:39 am
How much was this, please?
they charged me £540, apparently it took them 6 hours?! :.
f**k ME :cry:
When questioned, he told me its because it's an M Sport Z4 so the suspension technology is much more complicated than a normal car. I asked him what was complicated about a coil spring and a damper... his response was that "it's a more complex setup, and that's why the handling is so good, imagine what would happen if you put an engine like that in a golf, it would end up in a heap at the side of the road."
Anyway, my new problem is that one corner (the one that had the broken spring) is now higher than the others. Could that be just a case of the spring needing longer to settle, or is something else likely broken?
2014 E89 35is Valencia Orange 788M wheels (M2 Competition), E90 M3 control arms, Eibach Pro Kit Springs, MHD Stage 1
Nictrix
Spring broken?
Post by Nictrix » Fri Nov 11, 2022 4:52 pm
He's full of s**t.
I changed the rear springs on our old 23i and if it wasn't for one of the droplinks snapping it would have been done inside an hour.
Busterboo
Spring broken?
Post by Busterboo » Fri Nov 11, 2022 7:42 pm
Mmm. For my 35iS, the replacement OE spring & labour was ... er ... seventy quid.
Feels fine.
Vidi, vici, veni
Argyll Andy
Spring broken?
Post by Argyll Andy » Fri Nov 11, 2022 9:29 pm
tiglon wrote: Fri Nov 11, 2022 3:40 pm
f**k ME :cry:
I’m going to agree with Nictrix, I’d expect the rears to be done in an hour and the fronts around an hour each max.
Re the corner sitting higher I’m not sure, maybe damaged damper due to the broken spring? If settlement I’d expect them all to need to settle not just one corner. Just a punt but I’m taking it the adaptive stuff doesn’t need some sort of software/coding reset if worked on?
    E89 23i sDrive, Silver (Gone)
    Zed Baron
    Spring broken?
    Post by Zed Baron » Fri Nov 11, 2022 10:53 pm
    When my rear spring went my local dealer wanted £190 supply and fit, I managed to buy 4 oem ones for £80 off a car with 2k miles on it (wasn't damaged, guy building show car and replaced the suspension). My mechanic fitted the spring for £30, so £50 in all. We tried fitting a heavy duty spring but it was catching at the bottom, that's why the oem ones have the thin pigtail at the bottom and that's where they normally fail.
    Online
    B21
    Spring broken?
    Post by B21 » Fri Nov 11, 2022 11:13 pm
    Sounds like they didn’t assemble the new springs correctly…if the springs were ordered as a pack than re-assembly is the most likely cause..unless that damper (on the broken spring) was compromised..I assume at that price they would have checked everything perfectly…
    A very modified Atacama Yellow 35is :thumbsup:
    tiglon
    Spring broken?
    Post by tiglon » Fri Nov 11, 2022 11:34 pm
    You'd bloody hope they checked everything properly!
    The odd thing is, I've checked the height 4 times today, the first 3 times it was passenger rear that was higher, now its drivers side rear that's higher and passenger rear is fine :?
    Online
    B21
    Spring broken?
    Post by B21 » Fri Nov 11, 2022 11:39 pm
    tiglon wrote: Fri Nov 11, 2022 11:34 pm You'd bloody hope they checked everything properly!
    In that case it’s likely the springs are binding on the body of or parts of the damper…..
    Were the springs explicitly approved for the Electronic Damper version?
    tiglon
    Spring broken?
    Post by tiglon » Fri Nov 11, 2022 11:56 pm
    B21 wrote: Fri Nov 11, 2022 11:39 pm
    Specifically advertised as fitting 35is... have I been monumentally stupid here? :tumbleweed:
    Online
    B21
    Spring broken?
    Post by B21 » Sat Nov 12, 2022 12:02 am
    tiglon wrote: Fri Nov 11, 2022 11:56 pm
    Well looks like the spring is binding at various points…maybe it will settle down with use…..how’s the ride …have you tried various surf and speeds?
    tiglon
    Spring broken?
    Post by tiglon » Sat Nov 12, 2022 12:08 am
    B21 wrote: Sat Nov 12, 2022 12:02 am
    Ride feels good, I've only done 20 miles but that included a couple of very poorly maintained roads that I regularly drive down. One road felt (50-60mph) much smoother with the new springs and the other (20-30mph) was at worst the same as before. No real opportunity to test it properly around bendy bits yet.
    Online
    B21
    Spring broken?
    Post by B21 » Sat Nov 12, 2022 10:22 am
    Well I suggest you drive it for a while and just monitor it… :thumbsup:
    Jembo
    Spring broken?
    Post by Jembo » Sat Nov 12, 2022 10:35 am
    tiglon wrote: Thu Nov 10, 2022 10:06 pm ... and had a set of Eibach springs fitted ...
    The springs themselves were £150ish from Autodoc, then I made the mistake of not getting an estimate for the fitting so they charged me £540, apparently it took them 6 hours?! :o
    Pretty sure that in 6 hours I could learn how to do it, go buy the tools, change the springs myself, and have 30 mins spare at the end to make myself a nice sandwich.
    £540!!! for fitting, you were ROBBED
    In 2018 (& their prices haven’t gone up too much) ETA fitted 4 springs & dampers for £150 on my ///M
    I also found a place which sells just rears at a reasonable price as one of my Eibachs has just gone after 7k
    Joined the dark side with a ///M Hell Bronze Sepang Coupe :happyclap:
    Lifer 54
    Nictrix
    Spring broken?
    Post by Nictrix » Sat Nov 12, 2022 11:35 am
    B21 wrote: Fri Nov 11, 2022 11:13 pm Sounds like they didn’t assemble the new springs correctly…if the springs were ordered as a pack than re-assembly is the most likely cause..unless that damper (on the broken spring) was compromised..I assume at that price they would have checked everything perfectly…
    If its the rear that isnt sitting properly there isnt really any assembly involved.
    The spring and damper are seperate from each other.
    Basically to fit the rear spring almost all thats needed is to jack the car up, remove the wheel, undo the bottom damper mount and then while levering the wheel hub,disc etc down pull out the spring. To install lever the hub,disc etc down and put the new spring in place.
    tiglon
    Spring broken?
    Post by tiglon » Sat Nov 12, 2022 12:09 pm
    Thanks for all the suggestions and help. I've read a bit this morning on other BMW forums and it's maybe nothing unusual, just a case of not being on a 100% flat surface. One other explanation for a 3 series was that the fuel in the tank can sit on one side or the other and cause this.
    I'll be in for new front brakes fairly soon so, as suggested, I'll drive it and monitor then ask for a quick check when the brakes are done. Obviously at a different garage...
