Hi,
I believe i've got a common oil leak around the rocker cover, and oil filter housing. I've attached some images to this thread. Planning on buying these from ebay.
https://www.ebay.co.uk/itm/313051706085 ... R4r_ksOCYQ - rocker cover
https://www.ebay.co.uk/itm/393213408865 ... BMoNLi0IJh - oil filter housing
- Dylan
N54 Rocker Gasket (and Oil Filter housing gasket?)
- IMG_5101.jpg (165.57 KiB) Viewed 372 times
- IMG_5104.jpg (235.79 KiB) Viewed 372 times
- IMG_5103.jpg (178.51 KiB) Viewed 372 times
- IMG_5102.jpg (144.39 KiB) Viewed 372 times
- IMG_5100.jpg (173.77 KiB) Viewed 372 times
- Chippie
This is the one I bought
https://www.ebay.co.uk/itm/372833533202 ... media=COPY
And the oil cooler gasket set was from AUTODOC
- Chippie
Are you doing the work yourself?
Hi Chippie,
Yeah I'm planning on doing the job myself, unless you can recommend any good garages near Reading.
Thanks,
Dylan
Thanks,
Dylan
- Chippie
Only asked as all the how to tutorials say to remove the radiator fan, but when my son did mine he managed to get the oil filter house off without, which saved a bit of extra work and time.
From memory I think he used a 10mm ring spanner on the “star” head bolts as access with a socket is limited.
Also with the rocker cover he had to loosen the injector clamps to give a bit of wiggle room to get the cover off.
- hopz121
I believe BMW use elring Gaskets, but for something like this I would personally buy them from a BMW dealer. The last thing you want to do is replace the gaskets and find they still leak due to poor fitting gaskets.Dylan R. Fisher wrote: ↑Wed Oct 26, 2022 5:20 pm Hi,
- Dylan
Maybe get a quote from BMW it shouldn't be too bad.
2004 BMW E46 M3 Coupe - Manual - Silver Grey
2017 BMW F31 318d M-Sport - Auto - Glacier Silver
2007 Porsche Cayman 2.7 - Manual - Arctic Silver
2003 Renault Clio 172 Cup - Blue
2003 BMW E85 Z4 3.0i - Gone
2008 BMW E90 330i SE - Gone
What if cam cover is distorted.
I wouldn't mess about, change the cam cover with gaskets.
What i did on my N52 engine.
