Coolant advice pls
Coolant advice pls
I'm about to pop down to Halfords as I've notice the coolant is quite low. No issues on the dash but the floating stick is sitting at minimum. I don't plan to do any fancy like a full flush. Will save that for next spring me thinks. Shouldn't be driving it much in winter.
I'm just wondering if I need to open the bleed nipple while giving it a refill with some blue ready mix?
Thank you in advance
- bigwinn
Coolant advice pls
I’d say for a top up as long as it’s not a huge amount needed you should be ok not opening the bleed screw
EWS Delete PM me
Coding- airbags etc PM me
EWS Delete PM me
Coolant advice pls
Do I need NAP-Free or one of the other types?
Thanks Big
Thanks Big
- bigwinn
Coolant advice pls
Not a clue bud- someone will know on here
EWS Delete PM me
EWS Delete PM me
Coolant advice pls
No worries.
A quick online search states NAP-Free but the shop assistant swore blind I should follow the halfords system suggestion (Meg something)
Coolant advice pls
Go to a local Eurocarparts or parts distributor and get from there. Halfords has its place as a shop, but for better products and better prices , go to a mainstream supplier if you can. I used Comma X48 as a top up for mine and all is good.
E86 In sapphire black
Coolant advice pls
Thanks T, will give it a goThrustyjust wrote: ↑Mon Sep 26, 2022 7:34 pm Go to a local Eurocarparts or parts distributor and get from there. Halfords has its place as a shop, but for better products and better prices , go to a mainstream supplier if you can. I used Comma X48 as a top up for mine and all is good.
- Griffo46
Coolant advice pls
I have the N52 engine, to bleed the system, so we only have the option for auto bleed? Can we manually bleed the coolant some how? Not sure my battery will manage it.
2007 3.0si Roadster Stratus Grey/ Red Leather
2016 520d F10 M Sport Space Grey
- Mr Tidy
Coolant advice pls
Sadly I think the electronic bleed is the only option for the N52 engines.
Could you hook it up to a charger or a 2nd battery while you run the bleeding process?
Coupes because stunning!
Gone - Montego Blue
Gone - Ruby Black
Gone - Montego Blue
Gone - Ruby Black
- Griffo46
Coolant advice pls
Hey, I took the risk and managed without a charger. Nice easy process, managed to top up and bleed but I think my dip stick float is stuck. Doesn’t bob up, just stays at the bottom.
Anyone recommend me getting some long nose pliers and giving it a pull?
