Yet Another Wheel / Tyre Question
Alloy wheels and tyre discussion
TheDan
Post by TheDan » Thu Sep 22, 2022 11:44 am
Hi all,
I know we get a lot of wheel and tyre fitment questions, but I am looking for quite a specific use case and have searched and can only find a few posts with similar but not the same sizes, so I thought I'd ask.
I am going to be purchasing a set of Protrack One wheels to replace my buckled MV2s. I'm choosing Protracks because they are definitely capable of dealing with our terrible roads without buckling/cracking as they're battered around the ring by the Apex guys day in day out (brutal kerbs) and I love the look of them.
Here is my current setup:
  • Front: 18x8J ET47 + 12mm spacers (225/40/18)
  • Rear: 18x8.5J ET50 + 12mm spacers (245/35/18)
Below are the setups I am considering:
  • Front: 17x7.5J ET30 (235/45/17)
  • Rear: 17x9J ET38 (255/40/17)
  • Front: 17x9J ET38 (235/45/17)
  • Front: 18x8J ET45 + 12mm spacers (235/40/18)
  • Rear: 18x9J ET50 + 12mm spacers (255/35/18)
I know that the 18s above will fit because they're very similar to my current setup. However, I would like to run 17s for the extra sidewall and lower weight.
If I were to run the 17x7.5J on the front, the setup would be "over tyred" which I am pretty sure would destroy the sidewalls on track. What are people's thoughts on this?
I have played about on willtheyfit.com to get "acceptable" offsets and tyre fitments, but what I am mainly looking for is to see if anyone here has run a 9J on the front with a 235 tyre on an E85/E86 and whether they experienced rubbing or not.
TheDan
Post by TheDan » Mon Sep 26, 2022 1:51 pm
I know its very specific, but anyone use similar size fronts?
Online
Pondrew
Post by Pondrew » Mon Sep 26, 2022 2:06 pm
www.willtheyfit.com
Excellent tool for comparing wheel sizes, offsets etc. Gives lots of data.
F31 320i. Good car.
E89 20i Now fully dried
Mazda3 sold
TheDan
Post by TheDan » Mon Sep 26, 2022 2:11 pm
Pondrew wrote: Mon Sep 26, 2022 2:06 pm www.willtheyfit.com
I guess you didn't read all the first post :P
I checked willtheyfit.com and while its a great tool for checking offsets and poke, it really doesn't have enough information for whether a tyre will rub or not as it can't generate an accurate diagram for the tyre edge/corner.
This is why I am looking for a few (if they exist lol) first hand experiences of people using 9J fronts with 225-245 tyre sizes.
Online
Pondrew
Post by Pondrew » Mon Sep 26, 2022 2:32 pm
TheDan wrote: Mon Sep 26, 2022 2:11 pm I guess you didn't read all the first post :P
Nope, obviously I didn't. Sorry. :oops:
Note to self: pay more attention Pond!
F31 320i. Good car.
Mazda3 sold
Online
Mr Tidy
Post by Mr Tidy » Mon Sep 26, 2022 8:29 pm
I haven't run 9J fronts but when I got my MC it had CSL Reps on the front that were 8.5J with 235/35x19 MPSS tyres and they didn't rub at all - well not once I got rid of the spacers and got the coil-overs to a sensible ride height!
If it helps the rears were 9.5J with 265/30 x 19 tyres and they didn't rub either, although all the tyres were about half worn with 4mm of tread - new tyres would obviously be a few mm bigger.
Coupes because stunning!
Gone - Montego Blue
Gone - Ruby Black
Jellyfishfields
Post by Jellyfishfields » Mon Sep 26, 2022 11:19 pm
You've maybe seen this already and it's a different make, but the Apex fitment guide may offer some help with what you're looking for.
https://support.apexraceparts.com/hc/en ... ment-Guide
Good you mentioned the Protracks, I'd not heard of them but they look really good.
brillomaster
Post by brillomaster » Tue Sep 27, 2022 8:52 am
my standard ride height E85 3.0i ran a 245/35/R18 front tyre on a standard 8" front wheel with standard offset, that didnt have any rubbing...
TheDan
Post by TheDan » Wed Sep 28, 2022 12:45 pm
Jellyfishfields wrote: Mon Sep 26, 2022 11:19 pm You've maybe seen this already and it's a different make, but the Apex fitment guide may offer some help with what you're looking for.
Thanks for this, I did reach out to them asking about their 17x9J square setup and here was the reply:
"Thank you for reaching out in regards to your non-M Z4. With the 17x9" ET30 square setup, the most ideal tire size would be 245/40-17s at all four corners. While that setup will be a complete direct fit in the rear, the front will require a bit of work to fit without rubbing. Typically, depending on your ride height and specific tire selection, around -2.0 to -2.5 degrees of front camber will be required to fit this setup."
brillomaster wrote: Tue Sep 27, 2022 8:52 am my standard ride height E85 3.0i ran a 245/35/R18 front tyre on a standard 8" front wheel with standard offset, that didnt have any rubbing...
This is useful, thanks. I was slightly aware you were running a 245 on track from other posts you've made, but it gives me confidence a 235 tyre on a 9J should also be fine.
I am going to try to find someone nearby or at my next track day using a 9J (or 8.5J) with a 235 tyre to check fitment. Hopefully someone will be using this wheel/tyre combo.
