Cranking but won't start
Hello everyone.
I have had my Z4 for about 3 years and had 0 issues. Today, I was replacing the aux cable and suddenly the whole radio went off.
Next thing, I try to start the car and it doesn't start at all .
-- video: https://photos.app.goo.gl/9SWCnRuMc58EBu7F9
Any ideas on this?
Thank you!
Any ideas on this?
Thank you!
- enuff_zed
That clunking is telling you that the starter gets enough power to try to engage but not enough to turn it over.
I think you'll find it's nothing more sinister than a low battery.
But if it's dropped that quickly then it may be time for a new one.
Thank you for your reply. I replaced the battery last year and just before touching the aux I had no issues at all. I don't think it's because of that.
- enuff_zed
OK, but until you stick jump leads across it or at least check it's voltage, you won't know. Need to rule it out before you dive in deeper.
I suggested that because it's exactly the symptoms of a low charge battery that's all.
Very simple - acc battery. Use the battery charger or replace
Checked the battery with a multimeter.
Reads 0 with ignition off, ~7 with ignition on :S.
- enuff_zed
What are those figures? Not voltage?
Have you tried to jump start the car?
deandln, just trust me - try another battery or jump starter. It's standard BMWs problem , when the acc is not fully charged.
- pvr
If you worked on the audio, and had the igniition on (or the lights), that is enough to drain the battery.
Did you replace the battery by any chance with a Bosch unit as they are notoriously bad with this.
Current:
911-50 Black - unique spec
X5M - 575 hp of fun in a V8
Abarth 595 Comp.
Z4 3.0si Black Sapphire
VW ID.3
Previous:
Z4 3.0 Toledo
Abarth 595 Comp.
VW ID.3
Previous:
Z4 3.0 Toledo
- enuff_zed
Step 1 always has to be try a jump start surely!
- pvr
No, that is step 0
Current:
Abarth 595 Comp.
VW ID.3
Previous:
Z4 3.0 Toledo
Abarth 595 Comp.
VW ID.3
Previous:
Z4 3.0 Toledo
Radio is one of the first things to switch off when the battery runs out of charge. Power steering is last. Found that out after work whilst travelling down the M3
- enuff_zed
OP, are you starting to see a trend of thought here.
