Cold air intakes
Cold air intakes
Hi there. Me again.
So the car already had come filters installed, but the thing is they must just suck in hot air. Is there much of a gain between these and the standard box due to the air temps?
- IMG_20220920_182742.jpg (212.47 KiB) Viewed 475 times
2010 Black E89 35i
- enuff_zed
Cold air intakes
Hate to p*ss on your parade, but I think the general consensus is that the standard BMW set up is more efficient (if less pleasing on the eye) than a bunch of hot air filters.
Cold air intakes
Don't worry you are not as I was thinking the same thing. The noise is better but it must just be sucking hot air.
2010 Black E89 35i
- B21
Cold air intakes
Collective consensus is…
On anything apart from a serious turbo upgrade then the stock air box with stock filter is your best solution…
Actually sucking in hot air is not really an issue…BMS found negligible effects compared to say intercooler issues.
However most tests shows very poor level of filtration and hence if you do miles and/or it’s a keeper then alternative solutions are best..
- enuff_zed
Cold air intakes
Oh dear.
Methinks Peter is about to double your mortgage
Cold air intakes
enuff_zed wrote: ↑Tue Sep 20, 2022 8:38 pmOh dear.
2010 Black E89 35i
- B21
Cold air intakes
Gingerlomax wrote: ↑Tue Sep 20, 2022 8:31 pmEnjoy…
https://tteglobal.com/bmw/1-series/e82e ... gers?c=220
- 4C8610C5-0D7D-4A77-B428-A0889C834CA5.jpeg (62.78 KiB) Viewed 356 times
Cold air intakes
i was told the very similar by a very reputable tuner in UK when i was tuning my Megane. i was sure he has all the fancy stuff to sell me including a carbon air box with a cone insideB21 wrote: ↑Tue Sep 20, 2022 8:20 pm Collective consensus is…
so i just went for a better panel filter
Cold air intakes
I may switch back to original then with like you say a decent panel filter. Would the Map still be OK?
2010 Black E89 35i
- B21
Cold air intakes
Yes…OE filter from Mahle would be best solution..Gingerlomax wrote: ↑Thu Sep 22, 2022 8:43 am I may switch back to original then with like you say a decent panel filter. Would the Map still be OK?
