Windows not dropping for door open
Windows have stopped dropping automatically to open door, mirrors not folding and holding key on close does not shut windows. Plus indicator flash on close does not operate
All lights, indicators working as do internal lights
Windows go up and down when operated inside as does mirror movement and close
Car opens and locks and roof opens and closes
ista is showing FRM 9CBC FRM, short circuit at front door contacts, sensor voltage 0v, can read modules in ista and ncsexpert
Inpa has same with error code 9c bc 64 01 38 7c b6 00
Has anyone else had this issue ?
Is it an FRM issue or something else
Read on a search that the short out count can be reset if no shortcut
Appreciate any advice
- Zforbes
E89 sDrive 35is Titan Silver Kansas Black Leather
- Zforbes
Have a read, not 100% confident it's fixed yet
- Zforbes
No, there is a local refurb company I went to, was convinced it was frm but he said not...
- Zforbes
- Zforbes
The repair is just flashing the software, nothing physical and usually a duff FRM is more than a simple error, central locking failures lights etc.
There is a possibility of a corroded contact on the FRM but you would need to exchange the part to try.
Problem with mine is it goes away for months at a time.
Narrowing done the fault with ista and the door contacts are not sensing door opening.
so research has shown it could be a short 9cbc, frm program issue or frm itself
would someone share there nfrm trc output some I can compare and rule out this one out?
chassis e89
ecu =cas
process ecu nfrm
change to read - lessen
could someone send meba copy I know it may not be exact, but I did a backup at 234kb previous and now get a 36kb at first read
thanks anyone
chassis e89
ecu =cas
process ecu nfrm
thanks anyone
- Zforbes
Not sure what info you need or how to get it, it's also likely that I have a 9CBC error as my window drop issue occurred a couple of times this week.
Over summer mine has been faultless but the colder damper weather this week seems to have caused it to start again.
I take it your window drop error is constant and you've reset the window limit switches using the buttons or inpa/ista?
As far as I know, the trigger for the window drop is within the door lock actuator itself for each side so if both are out of action permanently then sending the FRM away sounds like it would be the first port of call.
If the error is more random and the reset procedure works for a short time then it could be power related.
Out of interest how old is the battery and what type is it?
Might sound a strange question but can be a regular cause of electrical gremlins.
Thanks for the replyZforbes wrote: ↑Fri Sep 30, 2022 2:08 pm Not sure what info you need or how to get it, it's also likely that I have a 9CBC error as my window drop issue occurred a couple of times this week.
Unfortunately it’s both sides and they both stopped at the same time, not intermittent
Inpa will not access window regulators api errors spdaten updated too
Ista accesses FRM but says short error 9CBC, will reset FRM and operate windows but when checking door operation they state closed always
- Zforbes
Did you get sorted with this? Always helpful to post a solution if you have one.birdy_z4 wrote: ↑Sun Oct 02, 2022 9:16 amThanks for the replyZforbes wrote: ↑Fri Sep 30, 2022 2:08 pm Not sure what info you need or how to get it, it's also likely that I have a 9CBC error as my window drop issue occurred a couple of times this week.
Not yet unfortunately things have progressively now got worse
Took the door card of drivers side and came back to it a week later and now the handbrake will not operate and engine will not start
So started a thread on battery as that may be the cause although it is saying 12.6v on test
Checked fuses all seem to be good
- Zforbes
Is the battery original from new?
Good place to start by the sounds of things, don't forget to register it when you get round to fitting.
