Mine used to fold but stopped so presume something in the FRM changed will let you knowZforbes wrote: ↑Mon Mar 27, 2023 9:50 amExcellent news, as others have commented understanding the fix and posting the resultsbirdy_z4 wrote: ↑Sun Mar 26, 2023 5:24 pmAfter months of head scratching finally fixed my 9CBC window drop issue
Fuses checked
FRM checked ( second hand one registered, same issue)
Door wire consistency for breaks checked on driver and passenger (and rechecked)
Fuse box out completely and all connections checked
Door locks changed drivers and passenger
Still had the issue
Jbl out, second hand registered still same issue
So thought that the FRM had switched off power due to short circuit
Lots of online research also got a reading from dr.gini that showed faults where originally in door contacts but now fixed
Found a post that suggested to try the below
Problem solved:
the
SNU_TK_ABFRAGE_OHNE_PULSE = aktiv
needed to be:
SNU_TK_ABFRAGE_OHNE_PULSE = nicht_aktiv
Programmed the FRM with the change and it worked !
Windows now dropping and closing …….
Now I’ve just got to solve why my mirrors no longer fold in when locking the car or out when opening
Oh plus an MOT overdue
I'm assuming someone's previously coded the mirrors to fold when locking?
Mine don't fold until I press the fold button, think that is standard.
Windows not dropping for door open
