rear parking sensors not working
After nearly hitting something very hard I realise the sensors aren't doing anything No beep no buzz no nothing dead The reversing lights still come on when in reverse but everything else does diddly squat Any body out there with any ideas Would a carly investigation tell me what's wrong?
Any help would be great
Does it do a long beep when you put the car in reverse?
Can you hear all the sensors making the sonic ticking when in reverse?
If you can't hear one of them that tells you which one needs replacing. I had this problem on my coupe and just ordered the part on ebay, and got a local garage to fit it for me, and problem was solved with parking sensors working perfectly again.
Sapphire Black E86 LN56 ZKJ Purchased Jan 2021 - Sold June 2022
Bilstein B12 Pro Kit
Eisenmann Quad Exhaust
BMW Z4M Rear Bumper
BMW Z4M Rear Bumper
No nothing no beep no nothing just silence
Online
Just some thoughts. Is the speaker working that makes the noise? Have you tried swapping out the PDC for another used one (can be had from ebay for about 20 quid)
Currently BMW Z4 E85 3.0si
Previously
BMW Z4 E86 3.0si
Vauxhall VX220 Turbo
Toyota Celica ST205 GT4
Nissan R33 Skyline GTST
Vauxhall VX220 NA
Nissan 350z
Previously
BMW Z4 E86 3.0si
Vauxhall VX220 NA
Nissan 350z
There is no vibration on any of the sensors so I guess that the PDC could be goosed Will try and get a replacement from ebay and see what happens
swapped the pdc control unit in the boot and now have clicking from all 4 sensors but not a beep from the speaker Removed the speaker from the footwell under the steering wheel Is there a way to test the speaker to see if it's dead
new sensors and new module sorted it for me beeps on all sensors
Plug a code reader in and check live data.
A creator c310+ is about £50. You’ll need someone to help while reading the data streams. Get them to walk up to each sensor holding a board. They kick in when 2m away and should move up and down accordingly.
I had 2 faulty ones when I got the car. One was dead and one detected and stuck straight to 0 even when you walked away.
You can also test with esta and inpa if you know anyone with the bmw diags.
thanks gollom 122 will go to my local indi who can do this for me
Hi spammy did you fit genuine bmw sensors or get them from ebay
hi nuddlez4 got them on ebay 29.99
Got mine eBay used genuine £10 each. Make sure you get the right ones as there are subtle differences between models.
my car did do the long beep like you mentioned when I put it into reverse, but now doesn't do that. Do you know what the problem might be?HGoward wrote: ↑Thu Sep 08, 2022 11:50 am Does it do a long beep when you put the car in reverse?
If there is no longer a long beep, and you can't hear the sensors ticking when listening to them. I would put money on it being the module itself now. And you could possibly have a dead sensor too if it initially did the long beep.Obicoke wrote: ↑Mon Jan 09, 2023 11:03 ammy car did do the long beep like you mentioned when I put it into reverse, but now doesn't do that. Do you know what the problem might be?HGoward wrote: ↑Thu Sep 08, 2022 11:50 am Does it do a long beep when you put the car in reverse?
BMW Z4M Rear Bumper
BMW Z4M Rear Bumper
Get a code reader. The creator c310+ is £50. You can read live data and test the sensors by having someone hold a plank of wood and approach each sensor individually.
I had 2 faulty ones (1 permanently on and 1 that stuck and didn’t release). I’d never have found that fault by the listening method.
