Down we go
- r2uzenblot
Down we go
Anyone looked at protecting the underside of the front skirt. On a couple of occasions I have thought it grounded as I went down a steep slope from car parks and although I took it very slowly I can see that there is a risk of grounding.
2023 G29 20i M Sport Portimao Blue
2021 Triumph Tiger GT Pro
2008 Triumph Sprint ST
2020 Cube Hybrid
1954 Two feet
2020 Cube Hybrid
1954 Two feet
Down we go
The part that contacts the ground is not the front bumper. It's the rubber aerodynamic flaps slightly behind the bumper but in front of both front wheels. They are flexible when contacting the ground and not too expensive to replace if it's damaged. Those rubber on my car almost certainly hit the ground when I exit office car park, which is indeed extremely annoying.
- Schaef
Down we go
It’s sound indeed worse than it really is.
- dr_john
Down we go
Mine has grounded sometimes on speed bumps, and that’s with non-MSport suspension.
Sapphire Black G29 2.0 MSport with Technology pack
- r2uzenblot
Down we go
Just had a good look and mine has grounded in one place despite the rubber flaps
2020 Cube Hybrid
1954 Two feet
2020 Cube Hybrid
1954 Two feet
Down we go
Mine grounds all the time. In fact I could see it when they showed me a video under the car. Not visible unless you go under the car so I’m not that fussed. Still try and hit bumps and slopes at an angle to reduce occurrences.
- Nanu
Down we go
There is a very steep entrance to the cattery we use and the front of the 35is just cleared the ground if I took it very carefully.
So far haven't risked it in the G29 which looks lower at the front
G29 M30i M Sport San Francisco Red
Previous
E89 35is Valencia Orange
E89 28i Crimson
E89 25i White
Previous
E89 28i Crimson
E89 25i White
- r2uzenblot
Down we go
It is lower at the front but there are so many places to catch you out. I have a mult storey I use and whilst I park 'out the way' the ramps are a nightmare. I might get some protective tape for underneath.
2020 Cube Hybrid
1954 Two feet
2020 Cube Hybrid
1954 Two feet
