My offside rear indicator suddenly developed an intermittent problem. One minute I’m indicating normally then suddenly it goes double speed and then corrects itself??
Any ideas?
E89 offside rear indicator suddenly intermittent not working
- enuff_zed
Well usually an indicator flashes double speed if the bulb at the other end of the car is not working.
Have you checked connections for the front and side bulbs?
- Zforbes
Check for water in the unit, very common problem, best fixed with new unit or both as can be visually different due to fading.
E89 sDrive 35is Titan Silver Kansas Black Leather
- B21
If it’s an E89 most likely, especially earlier cars with first generations of the tail lights…
I've got a 2009 offside rear light if you need one, only replaced as it didn't match my new nearside lens due to fading as mentioned. 125 delivered.
Another thing to perhaps look out for - One of my indicators went intermittently a couple of years ago. Then over winter it disappeared. Then when summer came round and I used the roof for the first time it came back. It still isn't fixed as it only happens rarely and I imagine it could be a pain to fix. Definitely happens when I use the roof then seems to settle down...
2011 E89 23i manual - "augmented" audio - Blue with cream leather.
As said, double speed usually indicates (sorry) a failed bulb.
If it is coming and going it could be a bulb that is failing, or a direty connection.
Put the indicators on then wobble/tap them to see which one stops flashing, my money is on the repeater on the side, either that or the one that's hardest to get to
2006 Imola Z4MC (wife's shopping trolley)
1990 Toyota Carina (Started as a free family heirloom, now apparently a Classic)
2016 Toyota Avensis 1.6D (yup, the *really* slow one).
2011 TDM900
1997 VFR750 project. 95% complete. Only 30% left to do.
2011 TDM900
Loads of electronics at bottom of indicator. Once significant moisture gets in it fails.
- CFSD
I've had the same issue on my rear left.
The seals leak and condensation/water will collect on the LED board. eventually it fails.
The board itself isn't a replaceable part, it's a whole new rear cluster to fix I'm afraid.
That said, the replacement itself is dead easy, if you've got a trim tool for the plastic plugs.
