Bought 2004 2.5 that has been sitting for a long time. At startup, it smokes a bunch of white smoke.
I bought a 2004 2.5l a few days ago. Runs smooth, no codes, etc. On startup, it blows A LOT of white smoke. Once warmed up, no issues. What would cause this and should I be worried?
- Chris_D
Condensate burning off perhaps. Give it a long/spirited run and see if it occurs on the following start/run after a full cooldown period.
- buzyg
Welcome to the forum. Hopefully you put a fresh tank of petrol in too.
That is plan for today. I didn't put in original post that it is very warm here. Seller says it was sitting and put maybe 500 miles on in last year
Yes, fresh fuel. . Went out for about half hour, still smoke when accelerating (white from what I can tell). Seller says most likely ccv from sitting. Does this make sense?
- StanDiego
What does it smell like? Burning oil will smell different that condensation burn off. It could be a number of things: blown head gasket, bad oil ring, crankcase ventilation valve, etc. How does your coolant look? Hopefully not milky.Donwiechers wrote: ↑Mon Aug 22, 2022 1:05 am Yes, fresh fuel. . Went out for about half hour, still smoke when accelerating (white from what I can tell). Seller says most likely ccv from sitting. Does this make sense?
2022 G29 s30i Black Sapphire Metallic / Magma Red / Shadowline / 799M Black spoke wheels "Darth ZEDer"
I'll check coolant tomorrow in car. Does not really smell like anything.
- Chippie
Welcome to the forum, if it doesn’t smell then it’s probably condensation, and we’d love to see a photo of your car.
- sw4nny
An italian tune may help,no cars like to be sat waiting to go out to play.
- Chris_D
Probably not the best idea considering it was only recently purchased.
Not knowing the maintenance history or state of the existing oil, coolant and timing chains/guides could be catastrophic by taking the engine to the rev limiter for any period.
It's way more contingent to to take the plugs out and use a camera/borescope to inspect for carbon deposits before assuming it would benefit from revving the arse out of it uneccessarily.
Doesn't really sound like a carbon build-up issue in any case.
- sw4nny
yeah but that wont be half as much fun.Chris_D wrote: ↑Mon Aug 22, 2022 11:44 amProbably not the best idea considering it was only recently purchased.
Only joking you are probably better taking Chris,s advice first then
Big cloud again at startup. I checked oil and coolant. Both look normal. Hhhmmmm. Guessing order the ccv parts and run it. Doesn't get hot, secondary fan kicks on, etc.
- Screenshot_20220817-113713.png (534.33 KiB) Viewed 377 times
- Screenshot_20220817-122749.png (546.19 KiB) Viewed 377 times
- Mr Tidy
Lovely - both those Z4s look great.
Hope you can cure your Roadster's smoking habit!
Coupes because stunning!
Gone - Montego Blue
Gone - Ruby Black
Gone - Montego Blue
Gone - Ruby Black
Lovely, red is definitely growing on me. It’s hard to like the rear bumper/fender reflectors on American cars though.
2003 Maldives Blue 3.0i auto
