E89 Roof problem
Shawn E
E89 Roof problem
Post by Shawn E » Thu Aug 18, 2022 1:05 pm
Hi all new to owning a Z4 so hopefully you can help?
I recently bought an E89 there seems to be a problem with the roof (hard top) I can open the roof using the key fob remotely by pressing the unlock button but it won't close the roof remotely by pressing the lock button, I have gone back to the garage who said that for it to close remotely it was an extra BMW and this is why it will only open remotely as my Z4 probably does not have this option to close remotely.
Is this right?
clarker63
E89 Roof problem
Post by clarker63 » Thu Aug 18, 2022 1:13 pm
Shawn E wrote: Thu Aug 18, 2022 1:05 pm Is this right?
yes and no. its not standard, and you need a Smartop to do that. its a non BMW add on. google it
35is, sadly gone, but not forgotten.
Reamesy
E89 Roof problem
Post by Reamesy » Thu Aug 18, 2022 1:16 pm
Shawn E wrote: Thu Aug 18, 2022 1:05 pm Hi all new to owning a Z4 so hopefully you can help?
Is this right?
I do believe unless you have comfort access you will need the SmartTop as suggested. Your car is behaving normally if it doesn’t have comfort access.
Currently; 2011 E89 23i SDrive M Sport Highline Titan Silver
Previously;
2014 SLK250CDI AMG Sport
2012 E89 SDrive 2.0 M Sport. White
2011 Audi TT Quattro
2006 Z4 2.5 Sport
2013 420D coupe
2002 Z3 2.2 Sport
1996 Z3 1.9
B21
E89 Roof problem
Post by B21 » Thu Aug 18, 2022 1:47 pm
Reamesy wrote: Thu Aug 18, 2022 1:16 pm
Is this right?
:thumbsup:
Correct..my first E89 didn’t have comfort access and could only remotely open the roof…my current E89 has comfort access and can open and close remotely the roof…comfort access can be recognised by a series of moulded ridges on the door handles..
A very modified Atacama Yellow 35is :thumbsup:
Pondrew
E89 Roof problem
Post by Pondrew » Thu Aug 18, 2022 2:03 pm
Always thought it really strange that they open with the remote but not close.
OP. Opening on the key/ remote without the engine running takes a good deal out of the battery. Z4s (and BMs in general) don't like low battery charge. I was advised to have the engine running when opening or closing the roof as a general rule. HTH :thumbsup:
F31 320i. Good car.
E89 20i Now fully dried
Mazda3 sold
B21
E89 Roof problem
Post by B21 » Thu Aug 18, 2022 2:20 pm
Pondrew wrote: Thu Aug 18, 2022 2:03 pm Always thought it really strange that they open with the remote but not close.
There are complex rules, harmonised between US and EU on standards related to remote closing of windows and roofs..
Essentially unless there is sophisticated anti trap measures then the remote control has to be both within close physical range of the car and must be continously held down during operations..
Given the hydraulic rams on the E89, a severe crushing force could be exerted on a limb inserted in such gaps..
Smartops break all those rules..
https://www.law.cornell.edu/cfr/text/49/571.118
https://eur-lex.europa.eu/legal-content ... print=true
refer..
And certainly given the current loads its good practice, where possible to have the engine running before, during and after roof operations..
RobbiZ4
E89 Roof problem
Post by RobbiZ4 » Sat Aug 20, 2022 10:20 am
B21 wrote: Thu Aug 18, 2022 2:20 pm ... its good practice, where possible to have the engine running before, during and after roof operations..
I don't agree with this:
Regarding "open/close the roof with a running engine":
From my point of view, for the 20-second roof process (20s x 20A = 400As) no more power is drawn from the battery than with 1x starter to start the engine (2s x 400A = 800As).
If that already damages the battery, what happens when the automatic start/stop system is active?
I think the often read engine-must-run recommendation is nonsensical! :cry:
But no harm. :thumbsup:
In between, I've added this (my) view into my recommendations:
⌛E89: Retractable Hardtop (roof) Maintenance (and additional) tasks
viewtopic.php?p=1861524#p1861524
Pardon, je suis Allemand :oops:
:ant:
E89 Roof Maintenance
viewtopic.php?t=130932
Y3 Roof Diagnostic System
viewtopic.php?f=23&t=129048
Ole gits rule
E89 Roof problem
Post by Ole gits rule » Sat Aug 20, 2022 10:31 am
RobbiZ4 wrote: Sat Aug 20, 2022 10:20 am
I use my key to open and close the roof all the time, especially in car parks as the doors are long and it makes exit / entering the car easier.
Not had any issues with the battery so far, although when its not used for a few days I stick a trickle charger on there.
M4 Vert in Yas Marina Blue
B21
E89 Roof problem
Post by B21 » Sat Aug 20, 2022 1:24 pm
Robbie, for once I’ll disagree with you.. :rofl:
I avoid starting the car as well…just keep driving :driving:
I always disable the stop start on our other cars.. :thumbsup: :tumbleweed:
Appreciate the mathematical calculations though.. :thumbsup:
RobbiZ4
E89 Roof problem
Post by RobbiZ4 » Sat Aug 20, 2022 1:30 pm
B21 wrote: Sat Aug 20, 2022 1:24 pm Robbie, for once I’ll disagree with you.. :rofl:
That's of course the best opion of all! :thumbsup: :thumbsup:
:ant:
