Broken bolt extractor
- pvr
Have a couple of bolts sheared off on the tractor that I need to take out. Looking at Amazon the sets generally have terrible reviews.
Any recommendations for a decent set?
Current:
911-50 Black - unique spec
X5M - 575 hp of fun in a V8
Abarth 595 Comp.
Z4 3.0si Black Sapphire
VW ID.3
Previous:
Z4 3.0 Toledo
Abarth 595 Comp.
VW ID.3
Previous:
Z4 3.0 Toledo
- DMike
Online
So you need an extractor for a tractor? Is that your current tractor or your previous one; ie your ex-tractor?
Comedy gold, Paul!
F31 320i. Good car.
E89 20i Now fully dried
Mazda3 sold
F31 320i. Good car.
Mazda3 sold
Living the dream huh Paul.....you know you've landed when you can buy a ride on....she's a beaut
- 291bb315ec40215895211157a544fd9a.jpg (82.1 KiB) Viewed 408 times
MR2 MK 2
E89 35is
G29
MR2 MK 2
E89 35is
G29
- pvr
The rest of you -
Current:
Abarth 595 Comp.
VW ID.3
Previous:
Z4 3.0 Toledo
Abarth 595 Comp.
VW ID.3
Previous:
Z4 3.0 Toledo
Unless they have broken off by bottoming out, they will probably come out with judicious use of a centrepunch applied (carefully) off centre in an anti clockwise direction on the broken bolt. Use a little heat on the part first. Removed many a broken bolt as a former toolmaker.
Sterling Grey 2004 e85 3.0i manual.
- ronk
I suggest a Good soaking with penetrating oil for a few days- drill a central hole - then use an extractor - if it doesn’t move. You are then in a good position to heli coil
- pvr
Thanks all, got the tool in but when I got in the barn today it was about 500 degrees so will wait for a bit cooler temps
Current:
Abarth 595 Comp.
VW ID.3
Previous:
Z4 3.0 Toledo
Abarth 595 Comp.
VW ID.3
Previous:
Z4 3.0 Toledo
at a pinch , drill a nice size hole and use an old torx bit from a cheap screwdriver set ,, grind a bit of a lead on it first then tap it in , and usually the actual tap will loosen the bolt enough to turn the broken bit out with a socket on the torx bit. ... dont go daft beating it in though ,,, just a '' nice '' fit is enough to sort it out , if not its time for the real thing.
- Joycey
Personally I would use a mig in this situation with a washer and nut. The heat generated welding the nut on will do all the work for you.
