B12 front camber
B12 front camber
Can the front camber be adjusted when b12 kit fitted, went to have wheel alignment done and was told they couldn’t adjust camber to front wheels,
- Ed Doe
B12 front camber
There is no additional camber adjustability offered with the B12 kit over the OE dampers. The reason is that the B12 Kit uses the normal OE Top-mounts.
Separately however, there is a small amount of camber adjustability to be had with the OE Top-mounts, by removing the locating pins, which is very easy to do.
Carbon Black '07 M Coupe: Intrax 1k2 Coilovers, AP-Racing, Raybestos ST45s, Tillets, Schroth, Vibratechnic, Apex EC7, Strongstrut, Eventuri, H&S, RTD, 4.1FD
Silver Grey '06 3.0si Coupe - SOLD
B12 front camber
Yes there is
It is not an official one but it works
Where the strut arm bolts to the front hub you fit spacers these are in the form of good quality flat washers
These are a few pence each
You will then need to fit slightly longer bolts 10mm 10.9 spec bolts these are about £1 each if that
Next you need a tracking company that will adjust it this way adding washers 1 at a time and recording the difference then setting it to what you want
I can’t find my photo of this on my car but I am sure I have posted it up here before I will have another look
B12 front camber
Here you go
B12 front camber
Had this done today, got to get new tie rods so he can finish the front, he said to keep front camber as it is, this sound right cheers
