Philips Sonicare
Onlineronk
Philips Sonicare
Are these just absolute junk or have I just been unlucky once again?
This is the third unit I’ve had and it’s only three months old and has mechanically failed - it’s just what’s needed on holiday - reverted to plan B Ie a toothbrush from the supermarket
Oral B when I’m home!
- enuff_zed
Philips Sonicare
Can't you just stick them in a glass beside the bed?
Onlineronk
Philips Sonicare
Next to the wig!
Philips Sonicare
As a (retired!) dentist, Oral B every time. I even have to buy my own now
I think about 99% of dentists use them.
Onlineronk
Philips Sonicare
That says it all - thanks
I have an ancient Oral B somewhere at home I might resurrect - or probably buy new.
Are there any features I should look out for? I don’t want to be mugged by advertisements again!
- MikeyH
Philips Sonicare
Oral B vote from me but they don't seem to last forever and drain fairly quickly. My wife's one is the same but seems to stay charged longer.
- enuff_zed
Philips Sonicare
I suspect that is because women just hold the brush still and carry on talking. Same job but no charge needed.
- MikeyH
Philips Sonicare
Philips Sonicare
Not really, the more expensive ones have more fancy bells and whistles but the basic ones do the same job for a lot less. The early ones suffered from "memory effect" on the rechargeable cells inside, hence the lack of holding charge after a few years use, which seems to be less of a problem with the newer models.
I do feel the urge to share this though:
https://youtu.be/V39qPwKpcGg
- sars
Philips Sonicare
Philips Sonicare for me, every girl needs that rapid oscillating action in their life
Gorgeous SFR Z4 M40i
Gone 2017 Iridium SL400, 2015 435d xDrive Convertible, 2012 E350 CDi Convertible, 2010 DSB Z4 sdrive30i, 2008 Audi A4 Cabriolet, 2006 Phoenix Yellow Z4 2.5Si, 2003 Saab 9-3 Convertible
- TitanTim
Philips Sonicare
Tim.
- TitanTim
Philips Sonicare
I had a Sonicare for years and seemed OK, never really gave it much thought really, it carried on until the shaft started over vibrating and went loose
Using an Oral now
Tim.
Using an Oral now
Tim.
- Scubaregs
Philips Sonicare
I would think most men would prefer oral to sonic.
Either or for the ladies.
- pvr
Philips Sonicare
Just bying the cheapest Oral B nowadays, I used to change the battery on the more expensive one but it was a faff.
Current:
911-50 Black - unique spec
X5M - 575 hp of fun in a V8
Abarth 595 Comp.
Z4 3.0si Black Sapphire
VW ID.3
Previous:
Z4 3.0 Toledo
Abarth 595 Comp.
VW ID.3
Previous:
Z4 3.0 Toledo
