Diagnostics
Diagnostics
what is a good diagnostic soft ware and where to get it? .
- Reamesy
Diagnostics
You can start with Bluetooth dongles like Carista £15 for the dongle then a subscription or Carly around £100 and BimmerLink needs a supported dongle and £30 for the Ap
Then standalone scanners like Autel MaxiPro or Com. These cost around 5-£600
Or get a laptop and install ISTA D or INPA for older cars. Then the right cable. K-DCAN for E85/86 and E89
All really depends on your intended use and needs.
Currently; 2011 E89 23i SDrive M Sport Highline Titan Silver
Previously;
2014 SLK250CDI AMG Sport
2012 E89 SDrive 2.0 M Sport. White
2011 Audi TT Quattro
2006 Z4 2.5 Sport
2013 420D coupe
2002 Z3 2.2 Sport
1996 Z3 1.9
Previously;
2006 Z4 2.5 Sport
2013 420D coupe
2002 Z3 2.2 Sport
1996 Z3 1.9
- enuff_zed
Diagnostics
Exactly.
What are you intending to to with it?
There are hand held code readers such as Creator 310 and Autophix 5900 which are very good at pinpointing most basic faults.
If you want to code stuff then you'll be needing something more complex. Likewise if you want to see fancy readouts from every module etc. in the car.
So far I have only bought the Autophix and it has served me well.
Examples being diagnosis of a sticking shuttle valve in the vanos, identifying which ABS sensor was playing up, and only last week enabling me to read the data-stream from the steering angle sensor to prove it wasn't malfunctioning.
However, I am well aware it has limitations. For example I couldn't code a new module to the car with it, or accurately diagnose the difference between a failing spark plug or a coil.
So if you can tell us why you want one then you'll get a more targeted response.
Diagnostics
well basically just to see if there are any faults and so i can pin point them my self without having a garage to tell me id rather tell them with in reason
- enuff_zed
Diagnostics
Then my suggestion would be the Creator 310 or the Autophix 5900.
From what I've read on here they both do more or less the same job.
- Griffo46
Diagnostics
This is good info for me too, I have been looking for something that I can use for faults and also changing light/ door lock settings etc too. I’ve read the details about these online but doesn’t state I can do all that too.
2007 3.0si Roadster Stratus Grey/ Red Leather
2016 520d F10 M Sport Space Grey
- Reamesy
Diagnostics
I would check they can code settings as most just do diagnosticGriffo46 wrote: ↑Wed Aug 03, 2022 8:30 amThis is good info for me too, I have been looking for something that I can use for faults and also changing light/ door lock settings etc too. I’ve read the details about these online but doesn’t state I can do all that too.
Previously;
2006 Z4 2.5 Sport
2013 420D coupe
2002 Z3 2.2 Sport
1996 Z3 1.9
Previously;
2006 Z4 2.5 Sport
2013 420D coupe
2002 Z3 2.2 Sport
1996 Z3 1.9
- enuff_zed
Diagnostics
These ones I've mentioned read codes and are very clear in helping to diagnose faults.Griffo46 wrote: ↑Wed Aug 03, 2022 8:30 amThis is good info for me too, I have been looking for something that I can use for faults and also changing light/ door lock settings etc too. I’ve read the details about these online but doesn’t state I can do all that too.
They will NOT be able to change settings. For that you need Carly or something similar.
Diagnostics
ok guys thanks for the info will take it onboard
Diagnostics
need a good all rounder really as got three car not all BMW s so one that does all makes of cars
- enuff_zed
Diagnostics
Hmmm. Beware the old saying "Jack of all trades, master of none!"
Diagnostics
Well aware of that one as an RR engineer I wont go far wrong.
- enuff_zed
Diagnostics
I didn't mean you, I meant buying a generic code reader may not be the best solution.
By the way, I was a RR engineer too. On RB199 and Avon 103.
Diagnostics
worked on rb 211 aero engines , parkside, and ansty. retired now.
- mac27040
Diagnostics
I would buy a second hand carly dongle then message me for the link to the software no annual fees...
3.0i SMG Supercharged,19" CSL, AvinUSA android 10.25” screen,DSP,M6 gearknob,Coilovers,Aero F-bumper,M r-bumper,Aero skirts,Facelift front & rear lights,M sports seats,Carbon Steering wheel,Intravee,Rervese cam,Hydrographics
