I have a Ford Fusion as my daily. Think they call it the mondeo for you. My wife has a Jeep Wranglerenuff_zed wrote: ↑Thu Aug 04, 2022 2:04 pmYou've obviously not grown up with Ford Capris.Gregory_tolson wrote: ↑Thu Aug 04, 2022 1:59 pmAverage temps for me in the winter are below freezing and when it snows we get usually over a foot, and the snow usually sticks around most of the winter. these things dont do snow and ice well with being RWD lol
However, in my neck of the woods we hardly ever get snow, though we do get lots of rain that then freezes overnight.
Overall unless up in the North of the UK I don't we suffer with extreme weather too much.
But of course there is a little bit of common sense involved.
With an X-Drive 1-series on the drive it's a no-brainer if the weather is crap.
WANTED Bilstein B4 kit
Bilstein B4 kit
- Rockhopper
Bilstein B4 kit
I only got stuck once last winter i think it was - i had to abandon it only about 500 yards from my house. I probably could have reversed it home but i didn't want to risk getting it totally stuck when i had the option to park it safely at the side of the road. I work from home mostly so i can live without the car a fair bit, I can also cycle and walk to work if I need to be in the office.
- kis
Bilstein B4 kit
Thanks Martin
My E85 Z4 3.0i SMG
1 Series - E87
4 Series - F36, F82 M4
5 Series - E34 (x2), E39
7 Series - E32
X5 - E53, E70
X6 - E71
1 Series - E87
7 Series - E32
X5 - E53, E70
X6 - E71
Bilstein B4 kit
Lets just skip over the numerous posts in that thread I linked and the professional mechanic within who worked on literally hundreds of them and said they are crap.True-Blue wrote: ↑Thu Aug 04, 2022 1:42 pmSo;SonnyA85 wrote: ↑Thu Aug 04, 2022 11:00 am
I can't find the post now because i looked through about 30+ threads but one guy switched his out after 40K miles for B4's as they were knackered. He drove the car 30K miles before selling it to a mate who then also drove it for 30K miles before selling it on and they were still okay. So he reckons B4's do around 100K miles and that is normal for a shock absorber. OEM however are crap and the numerous reports of them on here failing after 40-60K but they have no idea how long they have been knackered for because the only way to know is to take them off the car so they could have been knackered for years.
Some bloke on the internet (who you don’t know) replaced his knackered Sachs with B4’s drove it for 30k miles, then sold it to another bloke (who you don’t know) who then drove it for a further 30k miles, and he then sold it to a third bloke (who you don’t know) and the shocks where still fine….
Despite the fact that the third bloke didn’t remove the B4’s to test them? But with Sachs shocks you have to remove them to see if they’re knackered or not?
Is that about the size of it
Bilstein B4 kit
Let’s just skip over the fact that we’re talking about shocks on cars that are 15+ years old, even though they’ve may have done limited mileageSonnyA85 wrote: ↑Fri Aug 05, 2022 10:09 pmLets just skip over the numerous posts in that thread I linked and the professional mechanic within who worked on literally hundreds of them and said they are crap.True-Blue wrote: ↑Thu Aug 04, 2022 1:42 pmSo;SonnyA85 wrote: ↑Thu Aug 04, 2022 11:00 am
Let’s skip over the fact that you are basically making unsubstantiated claims that the O.E. Sachs shocks will be toast after 30k miles and B4’s with do twice as many miles ‘easy’
Let’s take the word of ‘your professional mechanic’ that Sachs make shocks out of chocolate and all the manufacturers that fit them to their brand new vehicles are fitting sub standard parts.
You contradict yourself in this thread and many others. If B4’s had been fitted at the factory, they would also be knackered after 15 years
Previous Z4’s :E89 30i, E89 20i, E85 3.0Si (X4) E85 3.0i, E86 3.0 Si, E85 2.5si, E85 2.5i
Bilstein B4 kit
Let’s face it, there aren’t many Z4 owners (there are some, granted) who will replace their shocks and then drive another 40-60k miles, so what does it matter?
It then comes down to cost, ride quality, aesthetics and the fact that non-OEM suspension is a declarable mod for insurance purposes.
2003 Maldives Blue 3.0i auto
Bilstein B4 kit
All excellent, valid pointsZedebee wrote: ↑Fri Aug 05, 2022 10:52 pm Let’s face it, there aren’t many Z4 owners (there are some, granted) who will replace their shocks and then drive another 40-60k miles, so what does it matter?
Bilstein B4 kit
I was not aware this ad had created such a discussion, nor did I realise this was still alive. Apologies for those that have had an input. It is very much appreciated.
Currently I'm opting for B4's with Msport springs (lesjofor). I'll be replacing the bump stops too with the M sport one which is shorter. Everything else will be placed back in (bar the bolts etc that need to be replaced when doing this sort of job).
Maldives Blue 2.5i E85
- enuff_zed
Bilstein B4 kit
New top mounts surely?Dr. Zed wrote: ↑Mon Aug 08, 2022 2:08 pm I was not aware this ad had created such a discussion, nor did I realise this was still alive. Apologies for those that have had an input. It is very much appreciated.
Bilstein B4 kit
You can also get thicker spring mounts so the car isn't lowered too much and hopefully gives a slightly better ride.Dr. Zed wrote: ↑Mon Aug 08, 2022 2:08 pm I was not aware this ad had created such a discussion, nor did I realise this was still alive. Apologies for those that have had an input. It is very much appreciated.
https://www.ebay.co.uk/itm/203168043551
these are only 2.5mm thicker than the originals so 5mm difference overall. That way your car will only be lowered by 10mm from the standard suspension rather than 15mm. I done this as I went for a higher profile rear tyre and didn't want to rub over potholes or speed bumps.
Bilstein B4 kit
enuff_zed,
Yes, of course. Top mounts is why I realise the shocks were shot. My nearside mount was cracking which prompted me to fix it.
