WANTED Bilstein B4 kit
Bilstein B4 kit
Definitely replace the springs on the car. Those rear coils are known for cracking where mine cracked in the pictures. Its not worth moving the springs over, plus those Lesjofor springs were veryyyyy inexpensive. I got the M sport ones since i wanted it just a tad lower.
Bilstein B4 kit
Well this is what's on my shock and matches no part numbers so I have no idea!
I'm replacing top mounts, shocks, knuckle bolt, and plastic cover and bump stop.
Should freshen it up nicely.
- IMG20220802131402.jpg (87.75 KiB) Viewed 186 times
- IMG20220802131428.jpg (88.96 KiB) Viewed 186 times
Maldives Blue 2.5i E85
Bilstein B4 kit
I always thought my car felt that bad over British roads because it was so low but I'm starting to realise it was likely the shocks being knackered for some time.Gregory_tolson wrote: ↑Tue Aug 02, 2022 1:15 pmI was nervous they would be too stiff, but my original suspension was so shot (since it was original) that they feel soooo good over bumps. I honestly would hit a pot hole on the original suspension and the car would rattle violently.
- enuff_zed
Bilstein B4 kit
I would agree about the rears, but never hear much about front spring issues?Gregory_tolson wrote: ↑Tue Aug 02, 2022 1:18 pm Definitely replace the springs on the car. Those rear coils are known for cracking where mine cracked in the pictures. Its not worth moving the springs over, plus those Lesjofor springs were veryyyyy inexpensive. I got the M sport ones since i wanted it just a tad lower.z4-1.jpgz4-2.jpg
The rears are dead easy to change on their own, so if they look ok you could still leave them and see?
- enuff_zed
Bilstein B4 kit
Yes, the 761895 number matches the MSport number on realoem if you check the link I sent.
Also the strut says Sport on the label.
So you do have MSport shocks.
Bilstein B4 kit
So could I mix the M sport coils with B4's regardless whether my car had m suspension to begin with?Gregory_tolson wrote: ↑Tue Aug 02, 2022 1:18 pm Definitely replace the springs on the car. Those rear coils are known for cracking where mine cracked in the pictures. Its not worth moving the springs over, plus those Lesjofor springs were veryyyyy inexpensive. I got the M sport ones since i wanted it just a tad lower.z4-1.jpgz4-2.jpg
Bilstein B4 kit
My springs aren't gone. The reason i originally removed the suspension was due to the top mount being cracked when I looked under the hood. But since then the shocks are clearly worn out too.Gregory_tolson wrote: ↑Tue Aug 02, 2022 1:18 pm Definitely replace the springs on the car. Those rear coils are known for cracking where mine cracked in the pictures. Its not worth moving the springs over, plus those Lesjofor springs were veryyyyy inexpensive. I got the M sport ones since i wanted it just a tad lower.
Bilstein B4 kit
I'll be honest, I haven't looked at the rears.. Not ordered any parts for them either
As for the parts number. The 'sport' I can see so thanks for that. Missed that, however the part number I can't match. What am I missing? You said the 761895 matched but I don't see that at all mate, sorry!
Bilstein B4 kit
yeah, that pic you posted is the M-sport suspension strut. My parts website claims the B6's are an OE replacement solely from a firmness standpoint. They told me B4 struts work with the M-sport coils but you lose that sporty firmness the M-sport struts provided from factory. The part number from factory is that 31316761895 number. The piston housing dimensions on the B6's and B4's is the same.
Last edited by Gregory_tolson on Tue Aug 02, 2022 1:33 pm, edited 1 time in total.
- enuff_zed
Bilstein B4 kit
Slowly getting closerDr. Zed wrote: ↑Tue Aug 02, 2022 1:25 pmMy springs aren't gone. The reason i originally removed the suspension was due to the top mount being cracked when I looked under the hood. But since then the shocks are clearly worn out too.Gregory_tolson wrote: ↑Tue Aug 02, 2022 1:18 pm Definitely replace the springs on the car. Those rear coils are known for cracking where mine cracked in the pictures. Its not worth moving the springs over, plus those Lesjofor springs were veryyyyy inexpensive. I got the M sport ones since i wanted it just a tad lower.
You now know you DO have MSport suspension. so you have the lower springs. If they ain't broke.......................
Can swap rears out later if they do break, but my logic would say with new dampers the spring will be under less stress as it's finally getting a little assistance.
So you either get the expensive B6 option, or consider going standard shock. In that case the B4 looks a little longer than the Sachs?
Add to that my experience with fitting standard Sachs on MSport springs with no detriment.
It's starting to come down to price and availability.
- enuff_zed
Bilstein B4 kit
Look at the table below the illustration.
Fourth '01' down. LH strut MSport Suspension.
Bilstein B4 kit
I like your idea of mixing B4's with M springs though. So enuff zed said that about the part number but according to realoem the front shocks are 31316785987 for non M and 31316785989 for M. So they're not matching what you're both saying which is odd...Gregory_tolson wrote: ↑Tue Aug 02, 2022 1:31 pm yeah, that pic you posted is the M-sport suspension strut. My parts website claims the B6's are an OE replacement solely from a firmness standpoint. They told me B4 struts work with the M-sport coils but you lose that sporty firmness the M-sport struts provided from factory. The part number from factory is that 31316761895 number.
Bilstein B4 kit
Yes, thank you for everyone's help in this!enuff_zed wrote: ↑Tue Aug 02, 2022 1:32 pm
Well my guy can get the B4's in this week and they're 170 odd for both (though autodoc are now having another sale, ffs. Typical).
So you're suggesting, if I opt for B4's is use the current springs and then the B4's with M sport bump stops?
If so my question is (more questions!)
Why is this dust cover a smooth cylinder as opposed to the ribbed one that came out of my car?
https://www.apd.co.uk/car-parts/suspens ... ber-103828
- enuff_zed
Bilstein B4 kit
Here you goDr. Zed wrote: ↑Tue Aug 02, 2022 1:35 pmI like your idea of mixing B4's with M springs though. So enuff zed said that about the part number but according to realoem the front shocks are 31316785987 for non M and 31316785989 for M. So they're not matching what you're both saying which is odd...Gregory_tolson wrote: ↑Tue Aug 02, 2022 1:31 pm yeah, that pic you posted is the M-sport suspension strut. My parts website claims the B6's are an OE replacement solely from a firmness standpoint. They told me B4 struts work with the M-sport coils but you lose that sporty firmness the M-sport struts provided from factory. The part number from factory is that 31316761895 number.
Bilstein B4 kit
Here are screen shots from RealOEM
