And had the N52 which is probably a different weight, hence the different shock.
WANTED Bilstein B4 kit
- enuff_zed
Bilstein B4 kit
Bilstein B4 kit
Haha, BMW definitely was quirky with their PN's. Though it always amazes me how similar this car is to the e46Dr. Zed wrote: ↑Tue Aug 02, 2022 1:58 pmI did this after you mentioned the 3 litre thing.Gregory_tolson wrote: ↑Tue Aug 02, 2022 1:56 pm yeah, real oem must be searching your VIN # wrong. Search solely based on what your car is versus the VIN.
Parts are now showing the same as you and enuff zed. Not that it matters ultimately as it's still the same B4 suspension I need but was just confusing me so much why it was different!
Bilstein B4 kit
Solving mystery after mystery here! Thanks for your invaluable input
I'm opting to go for B4's with M bump stops and undecided on whether to use original springs or get new ones but either way I'll stick with the B4 shock and M sport spring combo!
Maldives Blue 2.5i E85
- Rockhopper
Bilstein B4 kit
While you have the front struts apart you'd be daft not to swap the springs. Rear ones are easy to do with hardly any tools but the fronts are scary! No doubt someone will be along to say the opposite though
- enuff_zed
Bilstein B4 kit
I agree. Exactly what I was saying earlier about the rears. If the car is a keeper and you're not on a really tight budget then do the front springs while its all apart.Rockhopper wrote: ↑Tue Aug 02, 2022 3:19 pm While you have the front struts apart you'd be daft not to swap the springs. Rear ones are easy to do with hardly any tools but the fronts are scary! No doubt someone will be along to say the opposite though
Don't find the fronts scary tbh, but then I've had plenty of practice now.
Bilstein B4 kit
The issue is trying to find front springs in any sort of decent time frame..Rockhopper wrote: ↑Tue Aug 02, 2022 3:19 pm While you have the front struts apart you'd be daft not to swap the springs. Rear ones are easy to do with hardly any tools but the fronts are scary! No doubt someone will be along to say the opposite though
Bilstein B4 kit
I've been looking for springs but no luck in the UK really.enuff_zed wrote: ↑Tue Aug 02, 2022 3:30 pmI agree. Exactly what I was saying earlier about the rears. If the car is a keeper and you're not on a really tight budget then do the front springs while its all apart.Rockhopper wrote: ↑Tue Aug 02, 2022 3:19 pm While you have the front struts apart you'd be daft not to swap the springs. Rear ones are easy to do with hardly any tools but the fronts are scary! No doubt someone will be along to say the opposite though
I didn't find the fronts to bad either to be honest.
Bilstein B4 kit
you are probably fine with re-using them, mine looked ok if you go back further in the pics, the rears are what seem to have the common issues. Do you have RockAuto.com in the UK? They have front springs available from Lesjofors. They are Part Number 4008510. They are only $36. Maybe search that number up and see if it pops up on any UK parts providers.
Bilstein B4 kit
It's well known the oem/sachs only last around 30K. Bilstein's will last 60K+ easy.enuff_zed wrote: ↑Tue Aug 02, 2022 10:35 amI'll be honest, I think 30-40k on any standard set of shocks is reasonable considering the life they lead.Rockhopper wrote: ↑Tue Aug 02, 2022 10:22 am I've put B4's on my car - no idea on longevity yet but BWM OEM are Sachs and on my 100,000 mile old car the rear ones had been replaced at least once before so lets say 50k miles and they are shot (and not just a little bit shot - zero damping at either end). I personally don't think that's very good!
Have a search on the forums to confirm the above but Bilstein's are built to a much higher standard. In fact to confirm what others have said on the forum my mechanic just called as he's coming to do the EGR on Friday and he said himself Bilsteins are a quality shock as I'm just about to plac emy order and sent him a screenshot to double check everything before I do. 37% off today on autodoc and I have a visa card which gives me 5% cashback on the total amount too.
- enuff_zed
Bilstein B4 kit
Oh whatever..........SonnyA85 wrote: ↑Wed Aug 03, 2022 12:55 pmIt's well known the oem/sachs only last around 30K. Bilstein's will last 60K+ easy.enuff_zed wrote: ↑Tue Aug 02, 2022 10:35 amI'll be honest, I think 30-40k on any standard set of shocks is reasonable considering the life they lead.Rockhopper wrote: ↑Tue Aug 02, 2022 10:22 am I've put B4's on my car - no idea on longevity yet but BWM OEM are Sachs and on my 100,000 mile old car the rear ones had been replaced at least once before so lets say 50k miles and they are shot (and not just a little bit shot - zero damping at either end). I personally don't think that's very good!
- kis
Bilstein B4 kit
Late to this epic wanted thread but I find myself in a similar situation. I’ve got shocks (sach) and will be reusing the old rubber dust shield. I’m pairing it with my m sport springs… question is what bump stops or dust shield kit do I need to buy? Or will any be compatible?
My E85 Z4 3.0i SMG
1 Series - E87
4 Series - F36, F82 M4
5 Series - E34 (x2), E39
7 Series - E32
X5 - E53, E70
X6 - E71
1 Series - E87
7 Series - E32
X5 - E53, E70
X6 - E71
Bilstein B4 kit
I order febi bilstein today. Bump stops and cover in one set were around £7 each I thinkkis wrote: ↑Wed Aug 03, 2022 3:39 pm Late to this epic wanted thread but I find myself in a similar situation. I’ve got shocks (sach) and will be reusing the old rubber dust shield. I’m pairing it with my m sport springs… question is what bump stops or dust shield kit do I need to buy? Or will any be compatible?
103828 on autodoc
- kis
Bilstein B4 kit
What about 900 132? AUTODOC
My E85 Z4 3.0i SMG
1 Series - E87
7 Series - E32
X5 - E53, E70
X6 - E71
1 Series - E87
7 Series - E32
X5 - E53, E70
X6 - E71
Online
Bilstein B4 kit
Oh my days, is this coming from the same ‘fact based’ knowledge pool that electric car owners don’t have range anxiety?SonnyA85 wrote: ↑Wed Aug 03, 2022 12:55 pmIt's well known the oem/sachs only last around 30K. Bilstein's will last 60K+ easy.enuff_zed wrote: ↑Tue Aug 02, 2022 10:35 amI'll be honest, I think 30-40k on any standard set of shocks is reasonable considering the life they lead.Rockhopper wrote: ↑Tue Aug 02, 2022 10:22 am I've put B4's on my car - no idea on longevity yet but BWM OEM are Sachs and on my 100,000 mile old car the rear ones had been replaced at least once before so lets say 50k miles and they are shot (and not just a little bit shot - zero damping at either end). I personally don't think that's very good!
Where is the fact based evidence that Bilstein shocks last twice as long a Sachs shocks? 30k vs 60k
What you have is a situation where a lot of owners have replaced 10yr old+ Sachs shocks with bilstein’s in the belief they will be better, or because at the time they might have been cheaper than Sachs.
Do Bilstein offer a ‘’60,000 miles easy’’ guarantee?
If you have a look at Bilstein B8’s they’re developing a bit of a reputation for failure, and they’re an even more substantial build (different type of shock) to B4’s
O.P. You will be absolutely fine with Sachs shocks…. Most shocks will be dead after being run for 15 years even if they haven’t done really high mileage.
Previous Z4’s :E89 30i, E89 20i, E85 3.0Si (X4) E85 3.0i, E86 3.0 Si, E85 2.5si, E85 2.5i
